Up to 20% off select tools
Patching Surfboard Fiberglass
Views: 30K
View statistics:
Past 24 Hours:
6
Past 7 Days:
30
Past 30 Days:
122
All Time:
30,081
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
So a ding is basically any noticeable blemish in the board's fiberglass covering. It usually manifests itself as a cracked windshield like fracture. It could be long and skinny (like my rail dings, typically) or short and wide (if you hit a strategically placed jagged rock). You may also not think you have a ding at all, or anything worrying about, then you start noticing a slight yellow discoloration in a certain area-well, odds are you are letting in a little water in that area. Which affects how your board floats and even maneuvers.
    1. Patching Surfboard Fiberglass, Patching Surfboard Fiberglass: step 1, image 1 of 3 Patching Surfboard Fiberglass, Patching Surfboard Fiberglass: step 1, image 2 of 3 Patching Surfboard Fiberglass, Patching Surfboard Fiberglass: step 1, image 3 of 3
      • So, to begin, we need a nice clean working area. My place is small so I used my patio set (not the best idea though, as my wife flipped when she found out I was using toxic chemicals where we occasionally eat, just beware.)
      • Things you will need:
      • Surfboard with dings
      • Cleaning tools: wax comb, rag, and Gloves!!!
      • Resin, Q-Cell Filler, Hardener, Fiberglass Cloth
      • Mixing cup, stirring stick,Transparency
      • Sand paper: 1 rough grit and 1 fine grit
      • Starbucks (optional)
      Ask FixBot
    2. Patching Surfboard Fiberglass: step 2, image 1 of 3 Patching Surfboard Fiberglass: step 2, image 2 of 3 Patching Surfboard Fiberglass: step 2, image 3 of 3
      • Next, you need to identify the dinged areas and figure out which method you prefer to use. I used cloth repair on the bigger ones (and the rail ones) and then the sun cure on the small ones (because I have heard it works well enough on small stuff).
      Ask FixBot
    3. Patching Surfboard Fiberglass: step 3, image 1 of 3 Patching Surfboard Fiberglass: step 3, image 2 of 3 Patching Surfboard Fiberglass: step 3, image 3 of 3
      • Now we need to clean the dinged area of all the wax and fiberglass flakes.
      • Grab your comb and scrape any wax from around the area to be repaired.
      • Sand down, approximately 1/4", till you have a nice smooth surface.
      • Cut a small groove (in the direction of the ding) to give the repair mixture somewhere to seep into.
      Ask FixBot
    4. Patching Surfboard Fiberglass: step 4, image 1 of 3 Patching Surfboard Fiberglass: step 4, image 2 of 3 Patching Surfboard Fiberglass: step 4, image 3 of 3
      • Now we come to the mixing process.
      • First figure how much resin you are going to need to adequately cover the cloth piece with a little to spare to pre-dab the dinged area.
      • Add Filler, it helps to make the solution less watery and more workable
      • Then add the hardener; you only need a little and it really depends on the temp. Your box should say what is appropriate for your particular weather.
      Ask FixBot
    5. Patching Surfboard Fiberglass: step 5, image 1 of 2 Patching Surfboard Fiberglass: step 5, image 2 of 2
      • Mixing Process (Continued)
      • Put the fiberglass cloth that you cut into the mixture.
      • Stir the cloth in slowly to cover the cloth with mixture without causing air bubbles.
      Ask FixBot
    6. Patching Surfboard Fiberglass: step 6, image 1 of 3 Patching Surfboard Fiberglass: step 6, image 2 of 3 Patching Surfboard Fiberglass: step 6, image 3 of 3
      • Application Process:
      • Pre-dab the area with some of the solution, if there is a chunk of the fiberglass gone, use the solution generously to fill void.
      • Spread the soaked fiberglass cloth over the dinged area and smooth it out with your fingers.
      • Use the transparency to spread the cloth evenly, working out any noticeable bubbles.
      Ask FixBot
    7. Patching Surfboard Fiberglass: step 7, image 1 of 2 Patching Surfboard Fiberglass: step 7, image 2 of 2
      • Application Process (Continued)
      • Hold the transparency in place (be aware that it will not stay put).
      • Use tape (scotch, masking, painters) to secure the edges and make sure the transparency is held down tight
      Ask FixBot
      • Curing and Finishup:
      • Let the mixture cure.
      • It should take, depending on your weather, about 1 hour or so to dry completely.
      • Don't remove the transparency until dry.
      • Once dry, remove the transparency and use a fine sand paper to even out any new bumps from the new fiberglass surface.
      • Then, voila! your board should be back to working order. Get out there and this time try to be more careful on the trip back to the car. ;)
      Ask FixBot
3 other people completed this guide.
Author
with
Eric Doster
4,649 Reputation
2 Guides authored
1 Guide Comment
You forgot step 0 - choose a well-ventilated area (like the outdoors) before opening those aromatic chemical bottles.
Bote Man - Reply Share
Past 24 Hours: 6
Past 7 Days: 30
Past 30 Days: 122
All Time: 30,081
