Patch a Car Tire Patching Replacement
    1. Patch a Car Tire Patching Replacement, Identify leak: step 1, image 1 of 1
      • Look around the tire to see if there is any nail, cracks, or holes.
      • Once the leak is found, mark it.
      Ask FixBot
    2. Patch a Car Tire Patching Replacement, Evacuate air: step 2, image 1 of 1
      • Once the leak is identified, evacuate the air from the tire using the valve stem removal tool
      • Be sure to keep the small valve stem to reinstall after finished.
      Ask FixBot
    3. Patch a Car Tire Patching Replacement, Remove tire from wheel: step 3, image 1 of 1
      • Lay the wheel on the tire machine and use the tire iron to pull out the upper bead.
      • Use the tire machine to spin the wheel counter-clockwise.
      • Make sure to keep a strong grip on the tire iron otherwise it can jerk itself out.
      Ask FixBot
    4. Patch a Car Tire Patching Replacement, Remove tire (cont.): step 4, image 1 of 1
      • Once the upper bead is lifted off the wheel, remove the lower bead
      Ask FixBot
    5. Patch a Car Tire Patching Replacement, Remove nail (if applicable): step 5, image 1 of 1
      • Once the tire is removed from the wheel, removed the nail from the tire using the dikes
      Ask FixBot
    6. Patch a Car Tire Patching Replacement, Place tire on a secure surface: step 6, image 1 of 1
      • Place the tire on a secure and well lit area to prepare for a patch by grinding the inside of the tire
      Ask FixBot
    7. Patch a Car Tire Patching Replacement, Grind around the puncture: step 7, image 1 of 1
      • Use the die grinder to grind around the puncture to leave enough room for a patch to stick
      • Be sure to use a strong grip with a lot of pressure to keep the die grinder in control.
      Ask FixBot
    8. Patch a Car Tire Patching Replacement, Grind around the puncture (cont.): step 8, image 1 of 1
      • The surface area of the grinded area must be level and larger than the patch
      Ask FixBot
    9. Patch a Car Tire Patching Replacement, Apply vulcanizing cement: step 9, image 1 of 1
      • Apply an even layer of vulcanizing cement glue over the area that was grinded
      Ask FixBot
    10. Patch a Car Tire Patching Replacement, Place the tire patch: step 10, image 1 of 1
      • After the glue is dry, gently lay the patch at the center of the puncture.
      • The patch must be smaller than area that was grinded
      Ask FixBot
    11. Patch a Car Tire Patching Replacement, Seal the Patch: step 11, image 1 of 2 Patch a Car Tire Patching Replacement, Seal the Patch: step 11, image 2 of 2
      • Use the stitch roller to roll the patch in a crisscross pattern onto the tire for a permanent seal
      Ask FixBot
    12. Patch a Car Tire Patching Replacement, Reinstall the tire: step 12, image 1 of 1
      • Put the tire back onto the tire machine.
      • Start by installing the lower bead
      Ask FixBot
    13. Patch a Car Tire Patching Replacement, Reinstall the tire (cont.): step 13, image 1 of 2 Patch a Car Tire Patching Replacement, Reinstall the tire (cont.): step 13, image 2 of 2
      • After the lower bead is on the wheel
      • Use the tire iron to install the upper bead
      • Use a firm grip on the tire iron or it can swing back towards you.
      Ask FixBot
    14. Patch a Car Tire Patching Replacement, Inflate the tire: step 14, image 1 of 1
      • Use the air hose to inflate the tire to the correct psi
      • Typically, air pressure should be around 35-40 psi.
      • Insert the small tire valve stem you saved from earlier
      Ask FixBot
    15. Patch a Car Tire Patching Replacement, Finished: step 15, image 1 of 1
      • Job well done!
      Ask FixBot
Now that your repair is finished, it safe to say that you have given the tire a second chance by extending its life. You saved money by reusing this tire, additionally lowering the amount of rubber waste that is demolishing our environment.
Justin Guerra
283 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 101
All Time: 2,614
