Tools
Introduction
Go to step 1 ↓If you plan on replacing the buttons in your Parrot Skycontroller 2 then please look at our troubleshooting page to help fix issues. If the buttons will not work or cannot be cleaned, then it is necessary to replace them. To replace the buttons, use this guide.
Before beginning this repair please reference our Battery Replacement Guide to properly disconnect the battery to allow for safe working conditions.
Remove the seven black 11mm screws using the Torx TR6 screwdriver.
Pull back the sticker with your finger nail and remove the one black 11mm screw using the Torx TR6 screwdriver.
