Parrot Hydrofoil Orak Outrigger Replacement
  1. Parrot Hydrofoil Orak Outrigger Replacement, Outrigger: step 1, image 1 of 1
    • Place the drone so that the nose of the boat is pointing to the right.
    Ask FixBot
  2. Parrot Hydrofoil Orak Outrigger Replacement: step 2, image 1 of 3 Parrot Hydrofoil Orak Outrigger Replacement: step 2, image 2 of 3 Parrot Hydrofoil Orak Outrigger Replacement: step 2, image 3 of 3
    • Unscrew the 1 cm screw on the end of the plastic arm and connected to the foam outrigger using the T8 screwdriver fitting.
    • Remove the outrigger from the plastic arm.
    Ask FixBot
Alex Ziemann
135 Reputation
1 Guide authored
Cal Poly, Team 20-2, Livingston Fall 2016 Member of Cal Poly, Team 20-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G2
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 23
All Time: 367
