Parrot FLYPAD Joystick Replacement
    1. Parrot FLYPAD Joystick Replacement, Joystick: step 1, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Total of 6 Screws are located in the back of the controller.
      • Four 0.9mm T6 screws
      • Two 0.1mm T6 screws
      • Flip the Flypad over.
      • Remove the six screws using a T6 screwdriver.
      • Use a Magnetic Mat to prevent loss of screws. Set aside.
      Ask FixBot
    2. Parrot FLYPAD Joystick Replacement: step 2, image 1 of 1
      • Flip the Flypad over again and separate the front and back. Be sure to remove the foam adhesive that connects the front plate to the motherboard.
      • Be aware that the Buttons (L1,R1) may fall out. Remember to put them back in place during reassembly.
      • Use Ph0 tool to remove the screws holding the motherboard in place.
      • Gently remove the motherboard from the front plate.
      Ask FixBot
    3. Parrot FLYPAD Joystick Replacement: step 3, image 1 of 2 Parrot FLYPAD Joystick Replacement: step 3, image 2 of 2
      • Pop the joysticks out by pulling gently.
      Ask FixBot
    4. Parrot FLYPAD Joystick Replacement: step 4, image 1 of 1
      • Unscrew and replace joystick caps for a more comfortable grip.
      Ask FixBot
HUY NGUYEN
376 Reputation
3 Guides authored
UW Tacoma, Team S3-G5, Liner Spring 2017 Member of UW Tacoma, Team S3-G5, Liner Spring 2017
UWT-LINER-S17S3G5
5 Members
36 Guides authored
2 Guide Comments
Do you know where I can find replacement joystick caps like the one shown in Step 4, please?
cbeilstein - Reply Share
Same question as above regarding joystick caps please
Alex - Reply Share
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 15
All Time: 1,052
