Parrot AR.Drone 2.0 Motor Replacement
Video Overview
  1. Parrot AR.Drone 2.0 Motor Replacement, Propeller and Gear: step 1, image 1 of 2 Parrot AR.Drone 2.0 Motor Replacement, Propeller and Gear: step 1, image 2 of 2
    • Remove the foam body.
  2. Parrot AR.Drone 2.0 Motor Replacement: step 2, image 1 of 2 Parrot AR.Drone 2.0 Motor Replacement: step 2, image 2 of 2
    • Disconnect the battery by pulling the two red wires apart.
    • Remove the battery by releasing the battery retaining straps.
  3. Parrot AR.Drone 2.0 Motor Replacement: step 3, image 1 of 1
    • Remove the small retaining clip using a plastic opening tool.
    • Be careful as these clips can fly off and can be difficult to find.
  4. Parrot AR.Drone 2.0 Motor Replacement: step 4, image 1 of 3 Parrot AR.Drone 2.0 Motor Replacement: step 4, image 2 of 3 Parrot AR.Drone 2.0 Motor Replacement: step 4, image 3 of 3
    • The propeller, gear, and rod can be removed by simply lifting them off the motor.
  5. Parrot AR.Drone 2.0 Motor Replacement, Motor: step 5, image 1 of 2 Parrot AR.Drone 2.0 Motor Replacement, Motor: step 5, image 2 of 2
    • Disconnect the connector at the bottom of the motor assembly.
  6. Parrot AR.Drone 2.0 Motor Replacement: step 6, image 1 of 1
    • Remove the three 5mm screws on the top of the motor assembly with a PH00 bit.
  7. Parrot AR.Drone 2.0 Motor Replacement: step 7, image 1 of 1
    • Remove the three 5mm screws on the bottom again using a PH00 bit.
    • The three screws from the top are different from the three screws on the bottom.
  8. Parrot AR.Drone 2.0 Motor Replacement: step 8, image 1 of 2 Parrot AR.Drone 2.0 Motor Replacement: step 8, image 2 of 2
    • Carefully wiggle out the motor assembly out of the arm.
5 other people completed this guide.
David Hoyt
4,053 Reputation
41 Guides authored
Cal Poly, Team 25-89, Amido Spring 2010 Member of Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Members
61 Guides authored
2 Guide Comments
are the motors different on each side?
dbksoft - Reply Share
I need to know this also. replaced cross.member but did not put motors in original spots now my drone goes crazy and erratic
Steven Maloney - Share
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 53
All Time: 6,287
