Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Safety Glasses4.7
Introduction
Go to step 1 ↓Warning: This replacement guide may require the use of a soldering iron unless your replacement screen has speakers, microphone, etc. already attached.
This guide will show you how to remove the screen from your phone and replace it with a new screen.
Near the hinge of the phone there is a green circuit board.
On the underside of the board, there is an orange plastic connector that connects the battery to the screen.
The LCD screen is the metal square with the black LCD screen in the middle (this should not be confused with the clear plastic protective screen on the front of the phone).
Pull the LCD screen out with your fingers and disconnect the circuit board from the orange plastic connector with the spudger.
