Pantech Burst Motherboard Replacement
    1. Pantech Burst Motherboard Replacement, Motherboard: step 1, image 1 of 3 Pantech Burst Motherboard Replacement, Motherboard: step 1, image 2 of 3 Pantech Burst Motherboard Replacement, Motherboard: step 1, image 3 of 3
      • Power off your phone before beginning disassembly.
      • Turn over the phone so that you're facing the back cover.
      • Locate the indent(?) below the back cover.
      • Using a fingernail, pull up to remove the back cover.
      • Removing the back cover may require some force.
      Ask FixBot
    2. Pantech Burst Motherboard Replacement: step 2, image 1 of 3 Pantech Burst Motherboard Replacement: step 2, image 2 of 3 Pantech Burst Motherboard Replacement: step 2, image 3 of 3
      • Locate the silver battery. It is the big, rectangular, silver tape on black plastic object.
      • Find the gap between the battery and the rest of the device.
      • Using your fingernail, gently pull the battery up and away from the rest of the device.
      Ask FixBot
    3. Pantech Burst Motherboard Replacement: step 3, image 1 of 3 Pantech Burst Motherboard Replacement: step 3, image 2 of 3 Pantech Burst Motherboard Replacement: step 3, image 3 of 3
      • Undo all 8 visible screws using a phillips size 000 screwdriver.
      • The screws are marked in red on the picture.
      Ask FixBot
    4. Pantech Burst Motherboard Replacement: step 4, image 1 of 2 Pantech Burst Motherboard Replacement: step 4, image 2 of 2
      • Remove the SD card if there is one inserted into the phone.
      Ask FixBot
    5. Pantech Burst Motherboard Replacement: step 5, image 1 of 3 Pantech Burst Motherboard Replacement: step 5, image 2 of 3 Pantech Burst Motherboard Replacement: step 5, image 3 of 3
      • Using an opening tool or some other solid, flat-ended tool, begin pulling apart the phone from the indent below the USB port.
      • Continue using the tool, while moving around the edge of the phone until the two parts are largely disengaged.
      • Once there is space enough to pull the pieces apart with your fingers, you may do so.
      • Opening the phone may require a good amount of force.
      Ask FixBot
    6. Pantech Burst Motherboard Replacement: step 6, image 1 of 3 Pantech Burst Motherboard Replacement: step 6, image 2 of 3 Pantech Burst Motherboard Replacement: step 6, image 3 of 3
      • Unscrew the screw with a phillips size 000 screwdriver.
      • Disconnect the blue connector from the motherboard using a fingernail to lightly pull up.
      • Gently remove the SIM/SD card part.
      Ask FixBot
    7. Pantech Burst Motherboard Replacement: step 7, image 1 of 1
      • Gently disconnect the connectors attached to the motherboard using a fingernail to pull them up from the board.
      • Connectors are marked in blue in the image.
      Ask FixBot
    8. Pantech Burst Motherboard Replacement: step 8, image 1 of 3 Pantech Burst Motherboard Replacement: step 8, image 2 of 3 Pantech Burst Motherboard Replacement: step 8, image 3 of 3
      • Starting from the bottom and going around counterclockwise, carefully pry the motherboard out of the device.
      • Beginning with the side with the USB port may damage the phone.
      Ask FixBot
Kyle Kurashima
111 Reputation
1 Guide authored
Cal Poly, Team 15-1, Green Fall 2015 Member of Cal Poly, Team 15-1, Green Fall 2015
CPSU-GREEN-F15S15G1
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 30
All Time: 878
