Up to 20% off select tools
Pantech Breakout Battery Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
6
Past 7 Days:
27
Past 30 Days:
111
All Time:
2,578
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Better Introduction
Improve this guide by completing or revising its introduction.
    1. Pantech Breakout Battery Replacement, Removing Back Cover: step 1, image 1 of 3 Pantech Breakout Battery Replacement, Removing Back Cover: step 1, image 2 of 3 Pantech Breakout Battery Replacement, Removing Back Cover: step 1, image 3 of 3
      • Before proceeding, completely power off phone and disconnect power cords to avoid electrical shock.
      • Turn phone over so that the back side is facing up.
      • Using a finger, apply moderate pressure to the top of the back cover while sliding the cover down and off.
      • Lift and remove the back cover from the phone.
      Ask FixBot
    2. Pantech Breakout Battery Replacement, Removing the Battery: step 2, image 1 of 2 Pantech Breakout Battery Replacement, Removing the Battery: step 2, image 2 of 2
      • Locate the battery: It is a silver, rectangular object.
      • Insert a fingernail into the indent just below the battery about 0.5 inches from the bottom of the phone.
      • Then, apply pressure to the battery, pushing up and away from the phone. It will come out easily.
      Ask FixBot
Author
with
Ryan Murphy
898 Reputation
7 Guides authored
USF Tampa, Team 5-5, Mcgee Fall 2014 Member of USF Tampa, Team 5-5, Mcgee Fall 2014
USFT-MCGEE-F14S5G5
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 27
Past 30 Days: 111
All Time: 2,578
