Up to 20% off select tools
Pangolin PC Assembly
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
78
All Time:
304
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes - 2 hours
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
The printable files as well as the BOM are available on GitHub. Download the files here.
This guide is for Pangolin PC versions v1.0 and older.
Note: The photos in this guide may not reflect the parts in your version, as the PC in this guide was made with parts from multiple different versions.
    1. Pangolin PC Assembly, Print Your Parts!: step 1, image 1 of 1
      • Before beginning, you must have all the required parts already printed.
      • You may not be able to assemble your PC properly without printing all the parts provided.
      • Actually, you won’t be able to do anything if you don’t have your parts printed before you begin.
      Ask FixBot
    2. Pangolin PC Assembly, Bottom Plate & Display Arm: step 2, image 1 of 2 Pangolin PC Assembly, Bottom Plate & Display Arm: step 2, image 2 of 2
      • For steps 2-4, you will use the following:
      • 1x pangolinpc_base.
      • 1x pangolinpc_display_arm.
      • 4x M5 screws.
      Ask FixBot
    3. Pangolin PC Assembly, Bottom Plate & Display Arm (cont.): step 3, image 1 of 3 Pangolin PC Assembly, Bottom Plate & Display Arm (cont.): step 3, image 2 of 3 Pangolin PC Assembly, Bottom Plate & Display Arm (cont.): step 3, image 3 of 3
      • Grab the pangolinpc_display_arm and place it on top of the pangolinpc_base and flip over these pieces.
      • Make sure that the holes outlined match up so you may screw them together.
      • The reason that there isn’t a fourth hole in the third photo is because this is a pre-release prototype. Versions 0.3-alpha and later should have the fourth hole.
      Ask FixBot
    4. Pangolin PC Assembly, Bottom Plate & Display Arm (cont.): step 4, image 1 of 3 Pangolin PC Assembly, Bottom Plate & Display Arm (cont.): step 4, image 2 of 3 Pangolin PC Assembly, Bottom Plate & Display Arm (cont.): step 4, image 3 of 3
      • Screw in 4x M5 screws into the four holes.
      Ask FixBot
    5. Pangolin PC Assembly, Installing the SBC: step 5, image 1 of 3 Pangolin PC Assembly, Installing the SBC: step 5, image 2 of 3 Pangolin PC Assembly, Installing the SBC: step 5, image 3 of 3
      • For step 5, you will need the following:
      • The assembly from steps 2-4, which will be referred to now on as the "pangolinpc_base assembly."
      • The Single Board Computer (SBC), which in this case is a Raspberry Pi 5.
      • If you are going to install any HATs or accessories to the SBC, such as an PCIe HAT or the Active Cooler, install them now before proceeding.
      • You will place the SBC in the special slide-in area.
      • Line up the edges of the SBC with the notches in the slide-in area. Then slide the SBC down towards the rear of the pangolinpc_base.
      Ask FixBot
    6. Pangolin PC Assembly, Installing the Webcam Cable: step 6, image 1 of 3 Pangolin PC Assembly, Installing the Webcam Cable: step 6, image 2 of 3 Pangolin PC Assembly, Installing the Webcam Cable: step 6, image 3 of 3
      • For steps 6-8, you will need the following:
      • 1x Webcam cable.
      • The pangolinpc_base assembly.
      • Find the display/camera connectors on the right side of the SBC.
      • You will be plugging the cable into the connector nearest the Ethernet port on the SBC. This port is also labeled "CAM/DISP 0."
      • Pull up the brown clip of the connector.
      Ask FixBot
    7. Pangolin PC Assembly, Installing the Webcam Cable (cont.): step 7, image 1 of 2 Pangolin PC Assembly, Installing the Webcam Cable (cont.): step 7, image 2 of 2
      • Make sure you insert the smaller side of the cable into the SBC. The other side won't fit!
      • Insert the cable into the port. Don't force it! They are called "ZIF" (Zero Insertion Force) for a reason!
      • Insert the side of the cable with the gold contacts facing away from the Ethernet port.
      • Press down the brown clip to secure the cable.
      Ask FixBot
    8. Pangolin PC Assembly, Installing the Webcam Cable (cont.): step 8, image 1 of 3 Pangolin PC Assembly, Installing the Webcam Cable (cont.): step 8, image 2 of 3 Pangolin PC Assembly, Installing the Webcam Cable (cont.): step 8, image 3 of 3
      • Insert the fat end of the Webcam cable into the pangolinpc_display_arm and thread it through.
      • Pull the cable out through the top of the pangolinpc_display_arm.
      • There should be little slack inside the assembly, but don't pull too tight!
      Ask FixBot
    9. Pangolin PC Assembly, Installing the HDMI Cable: step 9, image 1 of 3 Pangolin PC Assembly, Installing the HDMI Cable: step 9, image 2 of 3 Pangolin PC Assembly, Installing the HDMI Cable: step 9, image 3 of 3
      • For steps 9-10, you will use the following:
      • 1x Micro-HDMI to HDMI cable.
      • Insert the Micro end into the top of the pangolinpc_display_arm, and thread it through so it comes out inside the assembly.
      Ask FixBot
    10. Pangolin PC Assembly, Installing the HDMI Cable (cont.): step 10, image 1 of 2 Pangolin PC Assembly, Installing the HDMI Cable (cont.): step 10, image 2 of 2
      • Insert the cable into the port nearest the USB-C port, marked HDMI0.
      Ask FixBot
    11. Pangolin PC Assembly, Installing the USB-C Cable: step 11, image 1 of 2 Pangolin PC Assembly, Installing the USB-C Cable: step 11, image 2 of 2
      • For steps 11-12, you will use the following:
      • 1x USB-C Power Cable.
      • I would highly recommend winding up the excess cable, making nice, neat loop near the power supply end of the cable.
      Ask FixBot
    12. Pangolin PC Assembly, Installing the USB-C Cable (cont.): step 12, image 1 of 2 Pangolin PC Assembly, Installing the USB-C Cable (cont.): step 12, image 2 of 2
      • Pull the USB-C cable through the pangolinpc_display_arm.
      Ask FixBot
    13. Pangolin PC Assembly, Installing the Power Strip: step 13, image 1 of 3 Pangolin PC Assembly, Installing the Power Strip: step 13, image 2 of 3 Pangolin PC Assembly, Installing the Power Strip: step 13, image 3 of 3
      • For steps 13-14, you will use the following:
      • 1x Power Strip.
      • Insert the power strip into the pangolinpc_base, where there is a large hole on the right side.
      • Push the power strip down into the pangolinpc_base until it stops.
      Ask FixBot
    14. Pangolin PC Assembly, Installing the Power Strip (cont.): step 14, image 1 of 2 Pangolin PC Assembly, Installing the Power Strip (cont.): step 14, image 2 of 2
      • In the second photo, this is what your pangolinpc_base should look like inside.
      Ask FixBot
    15. Pangolin PC Assembly, Installing the Anker Power Supply: step 15, image 1 of 3 Pangolin PC Assembly, Installing the Anker Power Supply: step 15, image 2 of 3 Pangolin PC Assembly, Installing the Anker Power Supply: step 15, image 3 of 3
      • For steps 15-16, you will need the following:
      • 1x Anker Power Supply.
      • You will be plugging the power supply into the port closest to the rear of the assembly.
      • Plug the power supply into the port.
      • Make sure the USB-C port on the power supply is closest to the front of the assembly. (See next step to see proper orientation.)
      Ask FixBot
    16. Pangolin PC Assembly, Installing the Anker Power Supply (cont.): step 16, image 1 of 3 Pangolin PC Assembly, Installing the Anker Power Supply (cont.): step 16, image 2 of 3 Pangolin PC Assembly, Installing the Anker Power Supply (cont.): step 16, image 3 of 3
      • Just like in the last step, make sure the USB-C port is closest to the front of the assembly.
      • Plug the USB-C cable into the power supply.
      Ask FixBot
    17. Pangolin PC Assembly, Installing the RPi Power Supply: step 17, image 1 of 3 Pangolin PC Assembly, Installing the RPi Power Supply: step 17, image 2 of 3 Pangolin PC Assembly, Installing the RPi Power Supply: step 17, image 3 of 3
      • For steps 17-18, you will need the following:
      • 1x Raspberry Pi power supply.
      • It is highly recommended to wind up the excess wire with a twist tie.
      • Plug the power supply into the bottom port on the power strip.
      • Make sure the cord coming out of the power supply is coming out closest to the front of the assembly.
      Ask FixBot
    18. Pangolin PC Assembly, Installing the RPi Power Supply (cont.): step 18, image 1 of 3 Pangolin PC Assembly, Installing the RPi Power Supply (cont.): step 18, image 2 of 3 Pangolin PC Assembly, Installing the RPi Power Supply (cont.): step 18, image 3 of 3
      • You will plug the USB-C cable into the Raspberry Pi's power port.
      • Plug in the cable.
      Ask FixBot
    19. Pangolin PC Assembly, What It Should Look Like So Far: step 19, image 1 of 1
      • This is what your pangolinpc_base assembly should look like inside.
      Ask FixBot
    20. Pangolin PC Assembly, Assembling the Power Button Assembly: step 20, image 1 of 1
      • For step 20, you will need the following:
      • 1x pangolinpc_power_button.
      • 1x pangolinpc_power_button_assembly_arm.
      • Hot glue.
      • Apply a wave pattern of glue to the pangolinpc_power_button and attach it to pangolinpc_power_button_assembly_arm as shown in the photo.
      • Make sure that the top of the pangolinpc_power_button is flush with the bottom of the pangolinpc_power_button_assembly_arm.
      Ask FixBot
    21. Pangolin PC Assembly, Installing the Power Button Assembly: step 21, image 1 of 3 Pangolin PC Assembly, Installing the Power Button Assembly: step 21, image 2 of 3 Pangolin PC Assembly, Installing the Power Button Assembly: step 21, image 3 of 3
      • For step 21-22, you will need the following:
      • The pangolinpc_power_button_assembly_arm assembly.
      • Hot glue.
      • Install the pangolinpc_power_button_assembly_arm assembly so that the power button is flush where the hole is for the power button on the pangolinpc_base.
      Ask FixBot
    22. Pangolin PC Assembly, Installing the Power Button Assembly (cont.): step 22, image 1 of 2 Pangolin PC Assembly, Installing the Power Button Assembly (cont.): step 22, image 2 of 2
      • Apply hot glue to the areas shown with the red lines.
      Ask FixBot
    23. Pangolin PC Assembly, Assembling and Installing the Plate Feet and Bottom Plate: step 23, image 1 of 3 Pangolin PC Assembly, Assembling and Installing the Plate Feet and Bottom Plate: step 23, image 2 of 3 Pangolin PC Assembly, Assembling and Installing the Plate Feet and Bottom Plate: step 23, image 3 of 3
      • For step 23-24, you will need the following:
      • 2x pangolinpc_plate_legs.
      • 1x pangolinpc_base_bottom_plate.
      • Hot glue.
      • You will be gluing the pangolinpc_plate_legs to the rear of the pangolinpc_base_bottom_plate where there are indents.
      • Do not glue the pangolinpc_plate_legs to the side that has holes inside the indents.
      Ask FixBot
    24. Pangolin PC Assembly, Assembling and Installing the Plate Feet and Bottom Plate (cont.): step 24, image 1 of 3 Pangolin PC Assembly, Assembling and Installing the Plate Feet and Bottom Plate (cont.): step 24, image 2 of 3 Pangolin PC Assembly, Assembling and Installing the Plate Feet and Bottom Plate (cont.): step 24, image 3 of 3
      • Install the pangolinpc_base_bottom_plate assembly to the bottom of the pangolinpc_base assembly as shown.
      Ask FixBot
    25. Pangolin PC Assembly, Installing the Last Bottom Plate Screws: step 25, image 1 of 2 Pangolin PC Assembly, Installing the Last Bottom Plate Screws: step 25, image 2 of 2
      • For step 25, you will need the following:
      • 2x M5 screws.
      • Screw in the screws into the back holes on the pangolinpc_base assembly.
      Ask FixBot
    26. Pangolin PC Assembly, Assembling and Installing the Rear Plate Legs: step 26, image 1 of 3 Pangolin PC Assembly, Assembling and Installing the Rear Plate Legs: step 26, image 2 of 3 Pangolin PC Assembly, Assembling and Installing the Rear Plate Legs: step 26, image 3 of 3
      • For step 26-27, you will need the following:
      • 2x M5 screws.
      • Hot glue.
      • Apply a thin bead of hot glue to the circumference of the screw head, as shown by the red circle.
      • Then place the screw into the pangolinpc_plate_legs so that the bottom of the screw head is flush with the top of the legs.
      Ask FixBot
    27. Pangolin PC Assembly, Assembling and Installing the Rear Plate Legs: step 27, image 1 of 2 Pangolin PC Assembly, Assembling and Installing the Rear Plate Legs: step 27, image 2 of 2
      • Install the M5 screw assemblies to the pangolinpc_base assembly.
      Ask FixBot
    28. Pangolin PC Assembly, Installing the VESA Mount: step 28, image 1 of 1
      • For steps 28-30, you will use the following:
      • The pangolinpc_vesa_mount
      • 4x M5 screws
      Ask FixBot
    29. Pangolin PC Assembly, Installing the VESA Mount (cont.): step 29, image 1 of 3 Pangolin PC Assembly, Installing the VESA Mount (cont.): step 29, image 2 of 3 Pangolin PC Assembly, Installing the VESA Mount (cont.): step 29, image 3 of 3
      • Thread the HDMI, USB-C, and Webcam cables through the middle square hole in the pangolinpc_vesa_mount.
      Ask FixBot
    30. Pangolin PC Assembly, Installing the VESA Mount (cont.): step 30, image 1 of 3 Pangolin PC Assembly, Installing the VESA Mount (cont.): step 30, image 2 of 3 Pangolin PC Assembly, Installing the VESA Mount (cont.): step 30, image 3 of 3
      • Screw the four M5 screws in the pangolinpc_vesa_mount, attaching it the pangolinpc_base assembly.
      Ask FixBot
    31. Pangolin PC Assembly, Installing the Display: step 31, image 1 of 1
      • For steps 31-35, you will need the following parts:
      • Raspberry Pi Display.
      • 4x M4 VESA screws.
      Ask FixBot
    32. Pangolin PC Assembly, Installing the Display (cont.): step 32, image 1 of 2 Pangolin PC Assembly, Installing the Display (cont.): step 32, image 2 of 2
      • Flip over the Display.
      • Flip over the white Display stand, making as flush with the back of the Display as possible.
      Ask FixBot
    33. Pangolin PC Assembly, Installing the Display (cont.): step 33, image 1 of 3 Pangolin PC Assembly, Installing the Display (cont.): step 33, image 2 of 3 Pangolin PC Assembly, Installing the Display (cont.): step 33, image 3 of 3
      • Take the pangolinpc_base assembly and have the power button pointing down, holding the Display arm above the Display's VESA mounting points.
      • Thread the Webcam cable under the white Display stand.
      • Thread it all the way so the end of the cable is sticking out the top end of the Display
      Ask FixBot
    34. Pangolin PC Assembly, Installing the Display (cont.): step 34, image 1 of 3 Pangolin PC Assembly, Installing the Display (cont.): step 34, image 2 of 3 Pangolin PC Assembly, Installing the Display (cont.): step 34, image 3 of 3
      • Plug the USB-C cable into the Display's USB-C port.
      • Plug the HDMI cable into the Display's HDMI port.
      • If you have any slack, just fold them in the well where the ports are.
      Ask FixBot
    35. Pangolin PC Assembly, Installing the Display (cont.): step 35, image 1 of 3 Pangolin PC Assembly, Installing the Display (cont.): step 35, image 2 of 3 Pangolin PC Assembly, Installing the Display (cont.): step 35, image 3 of 3
      • You will be screwing in 4x M4 VESA screws into these four holes on the pangolinpc_vesa_mount.
      • Make sure to support the pangolinpc_base to prevent any damage if the assembly is hanging down.
      Ask FixBot
    36. Pangolin PC Assembly, The Final Stretch!: step 36, image 1 of 1
      • You're almost done! 🫡👍
      • Take a moment to appreciate your work so far (or go get a coffee or a cookie).
      Ask FixBot
    37. Pangolin PC Assembly, Assembling and Installing the Webcam Assembly: step 37, image 1 of 2 Pangolin PC Assembly, Assembling and Installing the Webcam Assembly: step 37, image 2 of 2
      • For steps 37-43, you will use the following:
      • 1x pangolinpc_webcam_mount.
      • 1x pangolinpc_webcam_mount_plate.
      • 1x Raspberry Pi Camera Module.
      • 2x M5 screws.
      Ask FixBot
    38. Pangolin PC Assembly, Assembling and Installing the Webcam Assembly (cont.): step 38, image 1 of 3 Pangolin PC Assembly, Assembling and Installing the Webcam Assembly (cont.): step 38, image 2 of 3 Pangolin PC Assembly, Assembling and Installing the Webcam Assembly (cont.): step 38, image 3 of 3
      • Place the Camera Module onto the pangolinpc_webcam_mount_plate, matching up the four pins on the plate with the holes on the Camera Module.
      Ask FixBot
    39. Pangolin PC Assembly, Assembling and Installing the Webcam Assembly (cont.): step 39, image 1 of 2 Pangolin PC Assembly, Assembling and Installing the Webcam Assembly (cont.): step 39, image 2 of 2
      • Thread the Webcam cable through the slot near the top of the pangolinpc_webcam_mount.
      Ask FixBot
    40. Pangolin PC Assembly, Assembling and Installing the Webcam Assembly (cont.): step 40, image 1 of 3 Pangolin PC Assembly, Assembling and Installing the Webcam Assembly (cont.): step 40, image 2 of 3 Pangolin PC Assembly, Assembling and Installing the Webcam Assembly (cont.): step 40, image 3 of 3
      • Unscrew the top two M4 VESA screws holding the Display to the pangolinpc_vesa_mount.
      • Align the bottom two screw holes on the pangolinpc_webcam_mount.
      • Replace the two M4 VESA screws, attaching the pangolinpc_webcam_mount to the pangolinpc_vesa_mount and Display.
      Ask FixBot
    41. Pangolin PC Assembly, Assembling and Installing the Webcam Assembly (cont.): step 41, image 1 of 1
      • This is what the back of your Pangolin PC should look like after Step 40.
      Ask FixBot
    42. Pangolin PC Assembly, Assembling and Installing the Webcam Assembly (cont.): step 42, image 1 of 2 Pangolin PC Assembly, Assembling and Installing the Webcam Assembly (cont.): step 42, image 2 of 2
      • Attach the Webcam cable to the Camera Module.
      • If you need to be reminded on how to install ZIF cables, see Steps 6-7.
      • Make sure the gold contacts are facing towards the front, with the black part facing up as shown.
      • Insert the pangolinpc_webcam_mount_plate into the pangolinpc_webcam_mount.
      Ask FixBot
    43. Pangolin PC Assembly, Assembling and Installing the Webcam Assembly (cont.): step 43, image 1 of 2 Pangolin PC Assembly, Assembling and Installing the Webcam Assembly (cont.): step 43, image 2 of 2
      • Screw 2x M5 screws into the back of the pangolinpc_webcam_mount.
      Ask FixBot
    44. Pangolin PC Assembly, The End!: step 44, image 1 of 1
      • You are now done! Enjoy your new PC!
      • If you found any issues with this manual, or if anything wasn't entirely clear, please open an issue on GitHub here.
      Ask FixBot
Congrats! You’ve just made your Pangolin PC. If you ran into any hiccups, just open an issue on GitHub here, or if you are feeling adventurous and you think you have a solution, do a Pull Request!
Happy computing!
Author
with
S.I. Dalton
1,740 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 78
All Time: 304
