Panasonic Toughbook CF-XZ6 SSD Replacement
    1. Panasonic Toughbook CF-XZ6 SSD Replacement, Remove the back cover: step 1, image 1 of 3 Panasonic Toughbook CF-XZ6 SSD Replacement, Remove the back cover: step 1, image 2 of 3 Panasonic Toughbook CF-XZ6 SSD Replacement, Remove the back cover: step 1, image 3 of 3
      • Start by detaching the display unit from the keyboard base. Turn the laptop's display unit over so the bottom is facing up.
      • There are eight screws securing the back cover: Four along the bottom edge and Four along the top edge, hidden under a small cover
      • Use the rounded end of a spudger or a plastic opening pick to carefully remove the small top cover.
      • Remove all eight screws and keep them separate and organized to avoid mixing them.
      Ask FixBot
    2. Panasonic Toughbook CF-XZ6 SSD Replacement, Disconnect the battery: step 2, image 1 of 2 Panasonic Toughbook CF-XZ6 SSD Replacement, Disconnect the battery: step 2, image 2 of 2
      • Before continuing, disconnect the battery to prevent electrical damage.
      • The battery connector is located around the SSD and has multiple colored wires. Carefully peel back the thermal tape covering the connector.
      • Gently pull the connector straight out of the socket, pushing evenly from both sides. It may be slightly stiff due to the wire tension.
      • Once disconnected, press and hold the power button on the right side for about 5 seconds to discharge any remaining power.
      Ask FixBot
    3. Panasonic Toughbook CF-XZ6 SSD Replacement, Remove the SSD: step 3, image 1 of 3 Panasonic Toughbook CF-XZ6 SSD Replacement, Remove the SSD: step 3, image 2 of 3 Panasonic Toughbook CF-XZ6 SSD Replacement, Remove the SSD: step 3, image 3 of 3
      • The SSD is located next to the battery and is secured with one screw and thermal tape.
      • Move the thermal tape away from the retaining screw, then remove the screw.
      • The SSD will pop up at an angle of about 45 degrees. Slide the SSD out of the slot to remove it.
      • To install a replacement SSD, insert it at the same angle, push it fully into the slot, then press it down and secure it with the screw.
      Ask FixBot
Mohammed Mahir
194 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 51
All Time: 228
