Panasonic Toughbook CF-29 Wireless Card Replacement
    1. Panasonic Toughbook CF-29 Wireless Card Replacement, Battery: step 1, image 1 of 1
      • Locate the bay door for the battery on the left side of the laptop.
      Ask FixBot
    2. Panasonic Toughbook CF-29 Wireless Card Replacement: step 2, image 1 of 2 Panasonic Toughbook CF-29 Wireless Card Replacement: step 2, image 2 of 2
      • Slide the latch to the right and then down to unlock it.
      • Pull out the battery.
      Ask FixBot
    1. Panasonic Toughbook CF-29 Wireless Card Replacement, Back Cover: step 3, image 1 of 1
      • Begin by turning the laptop upside down with the handle towards you.
      • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
      Ask FixBot
    2. Panasonic Toughbook CF-29 Wireless Card Replacement: step 4, image 1 of 1
      • Remove the panel and set it aside.
      • Use a Phillips size 0 screwdriver to remove these 8 small screws.
      Ask FixBot
    3. Panasonic Toughbook CF-29 Wireless Card Replacement: step 5, image 1 of 1
      • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
      Ask FixBot
    4. Panasonic Toughbook CF-29 Wireless Card Replacement: step 6, image 1 of 2 Panasonic Toughbook CF-29 Wireless Card Replacement: step 6, image 2 of 2
      • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
      Ask FixBot
    5. Panasonic Toughbook CF-29 Wireless Card Replacement: step 7, image 1 of 1
      • Be careful when lifting the cover as you may damage some connections.
      • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
      Ask FixBot
    6. Panasonic Toughbook CF-29 Wireless Card Replacement: step 8, image 1 of 1
      • Now the back cover should be off and you can access the inside of the casing.
      Ask FixBot
    1. Panasonic Toughbook CF-29 Wireless Card Replacement, Wireless Card: step 9, image 1 of 1
      • Remove the black and white wires attached to the wireless card by simply pulling up.
      Ask FixBot
    2. Panasonic Toughbook CF-29 Wireless Card Replacement: step 10, image 1 of 1
      • Peel back the black cover to expose the clips holding in the wireless card.
      Ask FixBot
    3. Panasonic Toughbook CF-29 Wireless Card Replacement: step 11, image 1 of 1
      • Using a pair of plastic opening tools, push the two metal tabs away from the card.
      Ask FixBot
    4. Panasonic Toughbook CF-29 Wireless Card Replacement: step 12, image 1 of 2 Panasonic Toughbook CF-29 Wireless Card Replacement: step 12, image 2 of 2
      • The wireless card should now easily disengage from the motherboard.
      • Pull the card horizontally away from you to remove it from its housing.
      Ask FixBot
2 other people completed this guide.
Devon Augustus
130 Reputation
2 Guides authored
Cal Poly, Team 27-93, Amido Spring 2010 Member of Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Members
144 Guides authored
1 Guide Comment
what about the heatsinks of the processors? You don't fix the contact surface to the cover?
michael - Reply Share
Past 24 Hours: 0
Past 7 Days: 20
Past 30 Days: 55
All Time: 15,613
