Panasonic Toughbook CF-29 Touchscreen Replacement
    1. Panasonic Toughbook CF-29 Touchscreen Replacement, Battery: step 1, image 1 of 1
      • Locate the bay door for the battery on the left side of the laptop.
      Ask FixBot
    2. Panasonic Toughbook CF-29 Touchscreen Replacement: step 2, image 1 of 2 Panasonic Toughbook CF-29 Touchscreen Replacement: step 2, image 2 of 2
      • Slide the latch to the right and then down to unlock it.
      • Pull out the battery.
      Ask FixBot
    1. Panasonic Toughbook CF-29 Touchscreen Replacement, Touchscreen: step 3, image 1 of 1
      • Remove the four hinge screws from the back of the computer.
      Ask FixBot
    2. Panasonic Toughbook CF-29 Touchscreen Replacement: step 4, image 1 of 2 Panasonic Toughbook CF-29 Touchscreen Replacement: step 4, image 2 of 2
      • Open the laptop and remove the four indicated screws with a Phillips size 0 screwdriver.
      • Pry off the plastic strip which was previously held in place by the screws.
      Ask FixBot
    3. Panasonic Toughbook CF-29 Touchscreen Replacement: step 5, image 1 of 1
      • Remove the four hinge screws to allow the hinges to rotate up and move.
      Ask FixBot
    4. Panasonic Toughbook CF-29 Touchscreen Replacement: step 6, image 1 of 1
      • Remove 16 screws from the top of the closed laptop.
      • 12 Phillips size 1 screws
      • 2 Phillips size 0 screws
      • 2 Torx size 6 screws (T6)
      Ask FixBot
    5. Panasonic Toughbook CF-29 Touchscreen Replacement: step 7, image 1 of 1
      • Gently break the adhesive seal between the front and rear display cases with a plastic opening tool.
      • You will need to reapply the silicon adhesive during reassembly to ensure watertight seal.
      Ask FixBot
    6. Panasonic Toughbook CF-29 Touchscreen Replacement: step 8, image 1 of 1
      • Pull the top halve of the casing up revealing the inside of the screen
      Ask FixBot
    7. Panasonic Toughbook CF-29 Touchscreen Replacement: step 9, image 1 of 2 Panasonic Toughbook CF-29 Touchscreen Replacement: step 9, image 2 of 2
      • The top half of the case can be removed by sliding the tabs out from under the hinges.
      • This makes unplugging the screen wiring much easier
      Ask FixBot
    8. Panasonic Toughbook CF-29 Touchscreen Replacement: step 10, image 1 of 1
      • There are 4 wires that need to be unplugged to remove the screen.
      Ask FixBot
    9. Panasonic Toughbook CF-29 Touchscreen Replacement: step 11, image 1 of 1
      • For the first wire, peel back the silver cover tape to reveal the connection.
      Ask FixBot
    10. Panasonic Toughbook CF-29 Touchscreen Replacement: step 12, image 1 of 1
      • Pull the wiring away from the connection to release it.
      Ask FixBot
    11. Panasonic Toughbook CF-29 Touchscreen Replacement: step 13, image 1 of 1
      • Remove the 3 strips of black tape as shown to reveal connections 2 and 3.
      • Pull the wiring for each away from the connections to remove.
      Ask FixBot
    12. Panasonic Toughbook CF-29 Touchscreen Replacement: step 14, image 1 of 1
      • The 4th connection is already visible.
      • Depending on your model it might not be plugged into anything. If it is, remove it the same way the other 3 connections were removed.
      Ask FixBot
    13. Panasonic Toughbook CF-29 Touchscreen Replacement: step 15, image 1 of 2 Panasonic Toughbook CF-29 Touchscreen Replacement: step 15, image 2 of 2
      • Using a plastic opening tool, lift the screen as shown from the case and pull free.
      Ask FixBot
5 other people completed this guide.
Dylan Bloom
373 Reputation
4 Guides authored
Cal Poly, Team 27-93, Amido Spring 2010 Member of Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Members
144 Guides authored
1 Guide Comment
This guide is good for replacing the LCD screen, but it is not complete for the touchscreen panel, which requires some more delicate and precise steps. I think the title of the guide needs to be changed.
Thanks
Alessandro Cervelli - Reply Share
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 42
All Time: 18,048
