Up to 20% off select tools
Panasonic SL-MP73J Screen Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
78
All Time:
362
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 8 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your Panasonic SL-MP73J screen is cracked or damaged, use this guide to replace it. When functional, the screen displays the number of tracks in the CD, the total playtime, the number of albums, and the number of tracks. Take care when replacing this part, as it is connected by a delicate ribbon cable. Before replacing this component, make sure the batteries are removed from the device.
    1. Panasonic SL-MP73J Screen Replacement, Screen: step 1, image 1 of 1
      • Locate the open slider and push the sliding button to the right to open the CD player.
      Ask FixBot
    2. Panasonic SL-MP73J Screen Replacement: step 2, image 1 of 2 Panasonic SL-MP73J Screen Replacement: step 2, image 2 of 2
      • Open the battery cover and remove the batteries from the CD player.
      Ask FixBot
    3. Panasonic SL-MP73J Screen Replacement: step 3, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the nine 3 mm-long screws from the top interior plate.
      Ask FixBot
    4. Panasonic SL-MP73J Screen Replacement: step 4, image 1 of 2 Panasonic SL-MP73J Screen Replacement: step 4, image 2 of 2
      • Use an opening tool to lift the top interior plate from the lid.
      Ask FixBot
    5. Panasonic SL-MP73J Screen Replacement: step 5, image 1 of 3 Panasonic SL-MP73J Screen Replacement: step 5, image 2 of 3 Panasonic SL-MP73J Screen Replacement: step 5, image 3 of 3
      • Gently pull the ribbon cable and detach it from the ribbon cable connector.
      Ask FixBot
    6. Panasonic SL-MP73J Screen Replacement: step 6, image 1 of 2 Panasonic SL-MP73J Screen Replacement: step 6, image 2 of 2
      • Slide your plastic prying tool under the top left of the screen and slide it along the edge to detach the screen from the adhesive.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Mila Dafov
205 Reputation
2 Guides authored
UMass Dartmouth, Team 1-8, Botvin Fall 2025 Member of UMass Dartmouth, Team 1-8, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G8
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 78
All Time: 362
