Panasonic SDR-H85 Hard Drive Replacement
  1. Panasonic SDR-H85 Hard Drive Replacement, Battery: step 1, image 1 of 3 Panasonic SDR-H85 Hard Drive Replacement, Battery: step 1, image 2 of 3 Panasonic SDR-H85 Hard Drive Replacement, Battery: step 1, image 3 of 3
    • Gently slide the battery ejection button which is located underneath the battery and slide the battery out.
    • Once the battery is removed, you can safely dispose it and replace with a new one. Dispose battery at an authorized battery recycling center.
    Ask FixBot
  2. Panasonic SDR-H85 Hard Drive Replacement, Hard Drive: step 2, image 1 of 1
    • Remove three Phillips #00 screws from the left-hand side of the camera.
    Ask FixBot
  3. Panasonic SDR-H85 Hard Drive Replacement: step 3, image 1 of 1
    • Flip the camera so the bottom is facing upwards.
    • Remove four Phillips #00 screws to release the bottom portion of the camera panel.
    Ask FixBot
  4. Panasonic SDR-H85 Hard Drive Replacement: step 4, image 1 of 1
    • Open up the charging port of the camera.
    • Hold the charging port flap open, and remove the single Phillips #00 screw.
    Ask FixBot
  5. Panasonic SDR-H85 Hard Drive Replacement: step 5, image 1 of 1
    • This step needs to be done very slowly and carefully due to the delicate hard drive ribbon cable.
    • Open the camera cover slowly and enough to see the orange ribbon cable. Do not pull to release the ribbon cable from the hard drive.
    • Gently detach the connection of the ribbon cable from the hard drive by using the spudger to drive a wedge between the ribbon cable and the hard drive itself.
    • Do not use excessive force on the ribbon cable due to its delicate nature. You should feel a click when the connection has been broken.
    Ask FixBot
  6. Panasonic SDR-H85 Hard Drive Replacement: step 6, image 1 of 3 Panasonic SDR-H85 Hard Drive Replacement: step 6, image 2 of 3 Panasonic SDR-H85 Hard Drive Replacement: step 6, image 3 of 3
    • Remove three Phillips #00 screws from the interior of the camera.
    • Carefully pull out the hard drive from both the top and the bottom in alternative moves, first from the top and then from the bottom.
    • Use slight force because the rubber lining around the hard drive is very secure.
    • Remove the rubber lining of the hard drive.
    • Make sure you remove the rubber lining carefully as it could pop through and potentially hit you.
    Ask FixBot
2 other people completed this guide.
Hamza Lodhi
381 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 45
All Time: 1,438
