Panasonic RQ-2102 Cassette Holder Spring Replacement
  1. Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: step 1, image 1 of 3 Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: step 1, image 2 of 3 Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: step 1, image 3 of 3
    • Remove the three screws from the back of the device body.
    • Remove both screws from the battery compartment.
    • Remove the back of the device.
    • All screws in the body of this device are the same size.
    • When pulling apart the device, both sides are connected by a cord that could be damaged if care is not taken.
    Ask FixBot
  2. Panasonic RQ-2102 Cassette Holder Spring Replacement: step 2, image 1 of 3 Panasonic RQ-2102 Cassette Holder Spring Replacement: step 2, image 2 of 3 Panasonic RQ-2102 Cassette Holder Spring Replacement: step 2, image 3 of 3
    • Make sure the brass colored spring by the cassette door is in the correct position.
    • Remove the screw that holds the spring if broken.
    • Remove the spring from the device.
    Ask FixBot
  3. Panasonic RQ-2102 Cassette Holder Spring Replacement: step 3, image 1 of 2 Panasonic RQ-2102 Cassette Holder Spring Replacement: step 3, image 2 of 2
    • Replace the old spring with the new spring, making sure that it is installed in the correct position.
    • Insert the screw back into position, ensuring that it holds the spring.
    • If the spring is loose, tighten the screw.
    Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 26
All Time: 1,452
