Up to 20% off select tools
Panasonic RQ-2102 Buttons Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
103
All Time:
1,547
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
In this guide, you will learn how to replace the plastic buttons on this device. The number one most common problem that we found this device, and others like it, have is that the buttons get stuck. This can be a problem with the actual button itself, whether it has been bent, or a small piece has been snapped off. This guide will show you how to remove and replace one or all of your buttons
    1. Panasonic RQ-2102 Buttons Replacement, Buttons: step 1, image 1 of 3 Panasonic RQ-2102 Buttons Replacement, Buttons: step 1, image 2 of 3 Panasonic RQ-2102 Buttons Replacement, Buttons: step 1, image 3 of 3
      • Remove the three screws from the back of the device body.
      • Remove both screws from battery compartment.
      • Remove the back.
      • Make sure not to pull apart the cords that connect the device.
      Ask FixBot
    2. Panasonic RQ-2102 Buttons Replacement: step 2, image 1 of 3 Panasonic RQ-2102 Buttons Replacement: step 2, image 2 of 3 Panasonic RQ-2102 Buttons Replacement: step 2, image 3 of 3
      • Remove screws from the sides of the silver button pin roller.
      • Pry out the silver bar
      • Remove the desired button
      Ask FixBot
    3. Panasonic RQ-2102 Buttons Replacement: step 3, image 1 of 3 Panasonic RQ-2102 Buttons Replacement: step 3, image 2 of 3 Panasonic RQ-2102 Buttons Replacement: step 3, image 3 of 3
      • Insert the new button in place of the old button.
      • Put the silver pin roller back into its place over the buttons.
      • Put screws back into their original places by the sides of the silver pin roller.
      • If new buttons are not available, clean old buttons with a wet rag.
      • If the buttons do not work, ensure they are in their correct positions.
      Ask FixBot
3 other people completed this guide.
Author
with
Dmitriy Borisyuk
279 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 103
All Time: 1,547
