Up to 20% off select tools
Panasonic PV-GS9 microphone replacement
Views: 3.4K
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
34
All Time:
3,380
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide will inform you with a step-by-step process on how to disassemble the Panasonic PV-GS9 body to replace the microphone on the device if needed. The reasoning of the microphone replacement is because; no sound is either emitted from the camcorder's speaker or recorded by the microphone. If no sound from the speakers are emitted by any beeps on the button push, no playback volume, etc. there may be a problem with speaker. If sound is being emitted from button pushes but no playback, there may be a problem with the microphone. The microphone is located on the front of the device, below and to the left of the lens. Make sure nothing is obstructing the microphone, and if this doesn't help the microphone may need to be replaced.
    1. Panasonic PV-GS9 microphone replacement, Microphone Replacement: step 1, image 1 of 3 Panasonic PV-GS9 microphone replacement, Microphone Replacement: step 1, image 2 of 3 Panasonic PV-GS9 microphone replacement, Microphone Replacement: step 1, image 3 of 3
      • Locate the blue plastic tool opener, then remove both the round record/playback and record/power control knobs by prying it open from the camcorder.
      Ask FixBot
    2. Panasonic PV-GS9 microphone replacement: step 2, image 1 of 2 Panasonic PV-GS9 microphone replacement: step 2, image 2 of 2
      • Open the tape compartment.
      • Flip over the camcorder and find the two 4.5mm screws, which are approximately 2 inches apart.
      • Using a #00 Phillips screwdriver, remove the screws
      Ask FixBot
    3. Panasonic PV-GS9 microphone replacement: step 3, image 1 of 3 Panasonic PV-GS9 microphone replacement: step 3, image 2 of 3 Panasonic PV-GS9 microphone replacement: step 3, image 3 of 3
      • Use a plastic prying tool, remove the gray trim piece by opening and gently prying it off from top of the camcorder.
      • Be gentle when removing the trim piece. The plastic parts are fragile and can break easily.
      Ask FixBot
    4. Panasonic PV-GS9 microphone replacement: step 4, image 1 of 1
      • Rotate the camcorder so that the camera lens is facing you.
      • Remove the four black 4.5mm screws, sitting behind the battery.
      • Remove the 5th screw to the right of the battery dock.
      • Remove the battery by gently pulling away from the camcorder.
      • Organize the screws in a sorting compartment to avoid losing them.
      Ask FixBot
    5. Panasonic PV-GS9 microphone replacement: step 5, image 1 of 2 Panasonic PV-GS9 microphone replacement: step 5, image 2 of 2
      • Rotate the camcorder so that the tape compartment is facing you.
      • Remove the single 4.5mm black screw above the hook for the hand strap.
      • Undoing the strap on one end may help.
      • Rotate the camcorder so that the lens is facing you.
      • Remove the single 4.5mm black screw from the front panel.
      Ask FixBot
    6. Panasonic PV-GS9 microphone replacement: step 6, image 1 of 2 Panasonic PV-GS9 microphone replacement: step 6, image 2 of 2
      • Rotate the camcorder so that the bottom is facing towards you.
      • Remove the single remaining 4.5mm black screw from the bottom.
      • Remove the four silver 4.5mm screws from the body.
      Ask FixBot
    7. Panasonic PV-GS9 microphone replacement: step 7, image 1 of 1
      • Open the LCD screen on the side of the camcorder.
      • Using a #00 screwdriver, remove the two 4.5mm silver screws located on either side of the hinge of the LCD screen.
      Ask FixBot
    8. Panasonic PV-GS9 microphone replacement: step 8, image 1 of 2 Panasonic PV-GS9 microphone replacement: step 8, image 2 of 2
      • Carefully detatch the front cover from the body of the camcorder.
      • This should come apart with relative ease; however, a plastic pryer tool may help remove the panel if it is struggling to come apart.
      • Be careful as there is a ribbon cable attached to the front panel and the camcorder body, DO NOT tug at it when you remove this panel.
      Ask FixBot
    9. Panasonic PV-GS9 microphone replacement: step 9, image 1 of 2 Panasonic PV-GS9 microphone replacement: step 9, image 2 of 2
      • Using your fingers, carefully pull the ribbon cable away from the logic board to disconnect it.
      Ask FixBot
Author
with
Trevor Johnson
31 Reputation
2 Guides authored
Cal Poly, Team 7-9, Maness Spring 2010 Member of Cal Poly, Team 7-9, Maness Spring 2010
CPSU-MANESS-S10S7G9
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 34
All Time: 3,380
