Panasonic PV-GS9 Tripod Mount Replacement
    1. Panasonic PV-GS9 Tripod Mount Replacement, Microphone Replacement: step 1, image 1 of 3 Panasonic PV-GS9 Tripod Mount Replacement, Microphone Replacement: step 1, image 2 of 3 Panasonic PV-GS9 Tripod Mount Replacement, Microphone Replacement: step 1, image 3 of 3
      • Locate the blue plastic tool opener, then remove both the round record/playback and record/power control knobs by prying it open from the camcorder.
      Ask FixBot
    2. Panasonic PV-GS9 Tripod Mount Replacement: step 2, image 1 of 2 Panasonic PV-GS9 Tripod Mount Replacement: step 2, image 2 of 2
      • Open the tape compartment.
      • Flip over the camcorder and find the two 4.5mm screws, which are approximately 2 inches apart.
      • Using a #00 Phillips screwdriver, remove the screws
      Ask FixBot
    3. Panasonic PV-GS9 Tripod Mount Replacement: step 3, image 1 of 3 Panasonic PV-GS9 Tripod Mount Replacement: step 3, image 2 of 3 Panasonic PV-GS9 Tripod Mount Replacement: step 3, image 3 of 3
      • Use a plastic prying tool, remove the gray trim piece by opening and gently prying it off from top of the camcorder.
      • Be gentle when removing the trim piece. The plastic parts are fragile and can break easily.
      Ask FixBot
    4. Panasonic PV-GS9 Tripod Mount Replacement: step 4, image 1 of 1
      • Rotate the camcorder so that the camera lens is facing you.
      • Remove the four black 4.5mm screws, sitting behind the battery.
      • Remove the 5th screw to the right of the battery dock.
      • Remove the battery by gently pulling away from the camcorder.
      • Organize the screws in a sorting compartment to avoid losing them.
      Ask FixBot
    5. Panasonic PV-GS9 Tripod Mount Replacement: step 5, image 1 of 2 Panasonic PV-GS9 Tripod Mount Replacement: step 5, image 2 of 2
      • Rotate the camcorder so that the tape compartment is facing you.
      • Remove the single 4.5mm black screw above the hook for the hand strap.
      • Undoing the strap on one end may help.
      • Rotate the camcorder so that the lens is facing you.
      • Remove the single 4.5mm black screw from the front panel.
      Ask FixBot
    6. Panasonic PV-GS9 Tripod Mount Replacement: step 6, image 1 of 2 Panasonic PV-GS9 Tripod Mount Replacement: step 6, image 2 of 2
      • Rotate the camcorder so that the bottom is facing towards you.
      • Remove the single remaining 4.5mm black screw from the bottom.
      • Remove the four silver 4.5mm screws from the body.
      Ask FixBot
    7. Panasonic PV-GS9 Tripod Mount Replacement: step 7, image 1 of 1
      • Open the LCD screen on the side of the camcorder.
      • Using a #00 screwdriver, remove the two 4.5mm silver screws located on either side of the hinge of the LCD screen.
      Ask FixBot
    8. Panasonic PV-GS9 Tripod Mount Replacement: step 8, image 1 of 2 Panasonic PV-GS9 Tripod Mount Replacement: step 8, image 2 of 2
      • Carefully detatch the front cover from the body of the camcorder.
      • This should come apart with relative ease; however, a plastic pryer tool may help remove the panel if it is struggling to come apart.
      • Be careful as there is a ribbon cable attached to the front panel and the camcorder body, DO NOT tug at it when you remove this panel.
      Ask FixBot
    9. Panasonic PV-GS9 Tripod Mount Replacement: step 9, image 1 of 2 Panasonic PV-GS9 Tripod Mount Replacement: step 9, image 2 of 2
      • Using your fingers, carefully pull the ribbon cable away from the logic board to disconnect it.
      Ask FixBot
    1. Panasonic PV-GS9 Tripod Mount Replacement, LCD Panel Removal: step 10, image 1 of 2 Panasonic PV-GS9 Tripod Mount Replacement, LCD Panel Removal: step 10, image 2 of 2
      • Remove the indicated 4.5mm screws from the LCD side of the camera.
      Ask FixBot
    2. Panasonic PV-GS9 Tripod Mount Replacement: step 11, image 1 of 3 Panasonic PV-GS9 Tripod Mount Replacement: step 11, image 2 of 3 Panasonic PV-GS9 Tripod Mount Replacement: step 11, image 3 of 3
      • Place a plastic opening tool under the bottom of the blue panel beneath the camcorder.
      • Move the plastic opening tool up the side of the camcorder as shown. Carefully separate the LCD panel from the rest of the camcorder.
      • Remove the panel from the camcorder.
      • Using two tools can help for stability.
      Ask FixBot
    3. Panasonic PV-GS9 Tripod Mount Replacement: step 12, image 1 of 3 Panasonic PV-GS9 Tripod Mount Replacement: step 12, image 2 of 3 Panasonic PV-GS9 Tripod Mount Replacement: step 12, image 3 of 3
      • Before removing the LCD panel from the camcorder, disconnect all the ribbon cables joining the LCD panel to the logic board.
      • There may be multiple ribbon cables attached to the same point on the logic board.
      Ask FixBot
    1. Panasonic PV-GS9 Tripod Mount Replacement, Tripod: step 13, image 1 of 1
      • Remove two 4.5mm silver tripod mount screws.
      Ask FixBot
    2. Panasonic PV-GS9 Tripod Mount Replacement: step 14, image 1 of 1
      • Remove tripod mount carefully by prying it off with a plastic opening tool.
      Ask FixBot
Nate Chamness
33 Reputation
2 Guides authored
Cal Poly, Team 7-9, Maness Spring 2010 Member of Cal Poly, Team 7-9, Maness Spring 2010
CPSU-MANESS-S10S7G9
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 20
All Time: 1,819
