Panasonic PT-DW640US Lamps Replacement
    1. Panasonic PT-DW640US Lamps Replacement, Lamps: step 1, image 1 of 1
      • Remove the 31.8 mm screw from the front of the projector using a Phillips #1 screwdriver.
      Ask FixBot
    2. Panasonic PT-DW640US Lamps Replacement: step 2, image 1 of 1
      • Remove the front cover of the projector by pulling it towards you and to the left with two hands.
      • The front cover has a notch on the top so you must move side to side as you pull to remove it properly.
      Ask FixBot
    3. Panasonic PT-DW640US Lamps Replacement: step 3, image 1 of 1
      • Remove the six 31.8 mm screws from the inside using a Phillips #1 screwdriver.
      Ask FixBot
    4. Panasonic PT-DW640US Lamps Replacement: step 4, image 1 of 1
      • Reach into the inside and carefully pull out the left and right projector lamps.
      • It will require a bit of force in order to pull them out, but there should not be resistance after you first move them.
      • Caution: Be sure that the lamps are not dropped as the mercury contained within them is very harmful.
      Ask FixBot
    5. Panasonic PT-DW640US Lamps Replacement: step 5, image 1 of 1
      • After disposing of the old lamps properly, gather your new lamps and remove them from the packaging they came in.
      • The new lamps will come with screws to attach the parts.
      Ask FixBot
    6. Panasonic PT-DW640US Lamps Replacement: step 6, image 1 of 3 Panasonic PT-DW640US Lamps Replacement: step 6, image 2 of 3 Panasonic PT-DW640US Lamps Replacement: step 6, image 3 of 3
      • Place the new lamps into the projector.
      • The wide section of each lamp should face outwards with the screws towards you.
      Ask FixBot
    7. Panasonic PT-DW640US Lamps Replacement: step 7, image 1 of 1
      • Secure the lamps using the six 31.8 mm screws that came with the new lamps using a Phillips #1 screwdriver.
      Ask FixBot
    8. Panasonic PT-DW640US Lamps Replacement: step 8, image 1 of 1
      • Place the cover back on.
      • Ensure that the notch is on the top left of the cover when you place it.
      Ask FixBot
    9. Panasonic PT-DW640US Lamps Replacement: step 9, image 1 of 1
      • Screw the single 31.8 mm screw back in using a Phillips #1 screwdriver.
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 40
All Time: 361
