This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Introduction
Go to step 1 ↓If the screen on your Panasonic TZ71 is damaged, particularly if it is cracked or scratched, you need to replace it. This is shown here.
Tools
Turn off the camera and, for safety, remove the replacement battery.
Remove the four Phillips screws on the bottom.
Remove the two Phillips screws on the side with the door.
Remove the Phillips screw on the other side.
Slide the button board down a small distance.
Tilt the PCB up at an angle and hold it in place.
Flip up the black locking flap on the ZIF socket of the ribbon cable using the tip of a spudger.
Carefully pull the ribbon cable out with tweezers.
Follow the steps in reverse order to reassemble your device.
