Panasonic Lumix DMC-ZS8 Lens Replacement
  1. Panasonic Lumix DMC-ZS8 Lens Replacement, Lens: step 1, image 1 of 3 Panasonic Lumix DMC-ZS8 Lens Replacement, Lens: step 1, image 2 of 3 Panasonic Lumix DMC-ZS8 Lens Replacement, Lens: step 1, image 3 of 3
    • Take a Phillips Head screwdriver and remove the 2mm screws on the left and right side of the camera.
    Ask FixBot
  2. Panasonic Lumix DMC-ZS8 Lens Replacement: step 2, image 1 of 1
    • Remove the 3 Phillips 4mm screws located on the aluminum plating inside the camera.
    • Then remove the 3 Phillips 2mm screws located in the middle of the aluminum plating.
    Ask FixBot
  3. Panasonic Lumix DMC-ZS8 Lens Replacement: step 3, image 1 of 2 Panasonic Lumix DMC-ZS8 Lens Replacement: step 3, image 2 of 2
    • Lay the camera on the front side where the aluminum panel is facing up.
    • Once the camera is in the right position, lift up the aluminum plating.
    Ask FixBot
  4. Panasonic Lumix DMC-ZS8 Lens Replacement: step 4, image 1 of 2 Panasonic Lumix DMC-ZS8 Lens Replacement: step 4, image 2 of 2
    • Stand the camera up in the upright position.
    • Unplug both copper wiring plugs from the motherboard.
    Ask FixBot
  5. Panasonic Lumix DMC-ZS8 Lens Replacement: step 5, image 1 of 3 Panasonic Lumix DMC-ZS8 Lens Replacement: step 5, image 2 of 3 Panasonic Lumix DMC-ZS8 Lens Replacement: step 5, image 3 of 3
    • Lift your camera into the upright position
    • The camera lens should slide out. (Pry it out with a spudger or a plastic opening tool if needed)
    Ask FixBot
2 other people completed this guide.
Elijah Painter
180 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 37
All Time: 2,038
