Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement
  1. Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Removing External Screws: step 1, image 1 of 3 Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Removing External Screws: step 1, image 2 of 3 Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Removing External Screws: step 1, image 3 of 3
    • Remove Battery and Strap from unit.
    • Remove the 3 screws from the bottom
    • Remove screws from both sides of unit (4 screws total)
    Ask FixBot
  2. Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Removing the Side Panels: step 2, image 1 of 2 Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Removing the Side Panels: step 2, image 2 of 2
    • Remove both side panels from unit. You can pry them off with your finger nail or a spudger
    Ask FixBot
  3. Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Removing the Rear Cover: step 3, image 1 of 2 Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Removing the Rear Cover: step 3, image 2 of 2
    • Pry off rear cover. Make sure LCD remains in place.
    • There is a thin film of adhesive attaching the LCD to the rear cover. It releases easily with a little pressure. If necessary hold the LCD in place while removing the rear cover.
    Ask FixBot
  4. Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Removing the LCD: step 4, image 1 of 3 Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Removing the LCD: step 4, image 2 of 3 Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Removing the LCD: step 4, image 3 of 3
    • Release the Ziff clamp holding the LCD cable. 1st photo shows clamp in closed position.
    • You can use a spudger to release the clamp. You can also use your finger nail, but be careful it is very fragile.
    • Remove the LCD Flex from the clamp
    Ask FixBot
  5. Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement: step 5, image 1 of 3 Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement: step 5, image 2 of 3 Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement: step 5, image 3 of 3
    • You may need to pry off the window plate of your old screen if the new screen doesn't have one.
    • If required: Remove the window plate from your old screen if your new LCD doesn't have one. Save this part for re-install.
    Ask FixBot
  6. Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Clean up Window Plate and Reassemble: step 6, image 1 of 2 Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Clean up Window Plate and Reassemble: step 6, image 2 of 2
    Tool used on this step:
    Microfiber Cleaning Cloths
    $3.99
    Buy
    • If your new LCD does not come with a window plate: Tape your old window plate in place as shown in the photo. Make sure it lines up properly and fits into the grooves. This makes re-assembly much easier.
    • If necessary clean the window plate and LCD with a micro fiber dry cloth. Make sure there is no debris or dust before you re-install. DO NOT use any liquids.
    • Now just reverse the steps to re-assemble your camera with the new screen.
    Ask FixBot
Sales Cameraparts4you
3,396 Reputation
22 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 57
All Time: 911
