Panasonic Lumix DMC-ZS3 Lens Replacement
  1. Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: step 1, image 1 of 3 Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: step 1, image 2 of 3 Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: step 1, image 3 of 3
    • Remove the eleven 3 mm screws securing the covers to the ZS3.
    • Using too much pressure when removing the screws may strip the screws and complicate screw removal at a later time.
    Ask FixBot
  2. Panasonic Lumix DMC-ZS3 Lens Replacement: step 2, image 1 of 2 Panasonic Lumix DMC-ZS3 Lens Replacement: step 2, image 2 of 2
    • Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown.
    • Be sure to carefully and slowly lift the back cover. Forcefully lifting the back cover and fully separating it at this point may ruin internal connections.
    Ask FixBot
  3. Panasonic Lumix DMC-ZS3 Lens Replacement: step 3, image 1 of 2 Panasonic Lumix DMC-ZS3 Lens Replacement: step 3, image 2 of 2
    • Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
    • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
    Ask FixBot
  4. Panasonic Lumix DMC-ZS3 Lens Replacement: step 4, image 1 of 1
    • Remove the two LCD board ribbon cables out of their sockets.
    Ask FixBot
  5. Panasonic Lumix DMC-ZS3 Lens Replacement, Lens: step 5, image 1 of 1
    • Remove the three 3 mm black screws that surround the lens using a Phillips #00 screwdriver.
    Ask FixBot
  6. Panasonic Lumix DMC-ZS3 Lens Replacement: step 6, image 1 of 3 Panasonic Lumix DMC-ZS3 Lens Replacement: step 6, image 2 of 3 Panasonic Lumix DMC-ZS3 Lens Replacement: step 6, image 3 of 3
    • Flip up the locking flaps on the two LCD ribbon cable sockets with the spudger.
    • The LCD ribbon cables connect the back cover to the rest of the unit.
    • Use the spudger to disconnect the LCD ribbons.
    Ask FixBot
  7. Panasonic Lumix DMC-ZS3 Lens Replacement: step 7, image 1 of 3 Panasonic Lumix DMC-ZS3 Lens Replacement: step 7, image 2 of 3 Panasonic Lumix DMC-ZS3 Lens Replacement: step 7, image 3 of 3
    • Use your fingers or a spudger to gently remove the lens mechanism from the rest of the camera.
    • Excessive force may damage the camera. Be sure to lift the lens slowly and carefully to avoid damage to other parts.
    • Unlock lens mechanism located on the bottom of the device using your fingers.
    Ask FixBot
Kellen Ericson
18 Reputation
1 Guide authored
Cal Poly, Team 13-60, Johann Spring 2013 Member of Cal Poly, Team 13-60, Johann Spring 2013
CPSU-JOHANN-S13S13G60
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 65
All Time: 3,925
