Panasonic Lumix DMC-ZS25 Power Button Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
91
All Time:
1,172
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your Panasonic Lumix DMC - ZS25 is not turning on because of the power button, use this guide to safely open the camera and replace the button.
As the camera is used more often, the power button can begin to fail due to the constant use of it.
Make sure the new power button is of the right size to ensure a successful replacement.
Before using this guide, make sure the camera is unplugged from any connection and inspect the camera for any defects or loose wiring.
Tools
    1. Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: step 1, image 1 of 3 Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: step 1, image 2 of 3 Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: step 1, image 3 of 3
      • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
      • Remove the two 2.60 mm screws located next to the battery.
      Ask FixBot
    2. Panasonic Lumix DMC-ZS25  Power Button Replacement: step 2, image 1 of 1
      • Use the plastic opening tool to open the outer cover of your device.
      • The easiest place to open your device is from the HDMI port.
      • Open it gently to avoid breaking the cover.
      Ask FixBot
    3. Panasonic Lumix DMC-ZS25  Power Button Replacement: step 3, image 1 of 2 Panasonic Lumix DMC-ZS25  Power Button Replacement: step 3, image 2 of 2
      • Use a spudger to detach the ribbon cable.
      • Be careful when you use the spudger because you do not want to break the the ribbon.
      Ask FixBot
    4. Panasonic Lumix DMC-ZS25  Power Button Replacement: step 4, image 1 of 3 Panasonic Lumix DMC-ZS25  Power Button Replacement: step 4, image 2 of 3 Panasonic Lumix DMC-ZS25  Power Button Replacement: step 4, image 3 of 3
      • Remove the button board using the plastic opening tool.
      • Remove the screen. Lift the screen from the right hand side.
      • After your hear a "click" sound, you have successfully opened the screen.
      Ask FixBot
    5. Panasonic Lumix DMC-ZS25  Power Button Replacement: step 5, image 1 of 2 Panasonic Lumix DMC-ZS25  Power Button Replacement: step 5, image 2 of 2
      • Remove the two black screws that are located beneath the screen.
      • Lift the metal cover using the plastic opening tool.
      Ask FixBot
    6. Panasonic Lumix DMC-ZS25  Power Button Replacement: step 6, image 1 of 2 Panasonic Lumix DMC-ZS25  Power Button Replacement: step 6, image 2 of 2
      • Use the plastic opener to remove the side covers.
      Ask FixBot
    7. Panasonic Lumix DMC-ZS25  Power Button Replacement: step 7, image 1 of 2 Panasonic Lumix DMC-ZS25  Power Button Replacement: step 7, image 2 of 2
      • After removing the side covers, you will be able to take away the front cover with your hands.
      • Do not apply too much pressure on the outer cover of your device to avoid damage.
      Ask FixBot
    8. Panasonic Lumix DMC-ZS25  Power Button Replacement: step 8, image 1 of 1
      • To release the top cover of the camera, you need to open the 3.70 mm screw shown in the picture.
      Ask FixBot
    9. Panasonic Lumix DMC-ZS25  Power Button Replacement: step 9, image 1 of 1
      • Remove the top cover using the plastic opening tool.
      Ask FixBot
    10. Panasonic Lumix DMC-ZS25  Power Button Replacement: step 10, image 1 of 3 Panasonic Lumix DMC-ZS25  Power Button Replacement: step 10, image 2 of 3 Panasonic Lumix DMC-ZS25  Power Button Replacement: step 10, image 3 of 3
      • After removing the top cover of the camera, you will be able to easily remove the power button with your hand.
      Ask FixBot
Abbas Khan
482 Reputation
4 Guides authored
USF Tampa, Team 9-5, Brown Winter 2015 Member of USF Tampa, Team 9-5, Brown Winter 2015
USFT-BROWN-W15S9G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 91
All Time: 1,172
