Panasonic Lumix DMC-TZ5 button board Replacement
    1. Panasonic Lumix DMC-TZ5 button board Replacement, Back Cover: step 1, image 1 of 1
      • Remove the battery and memory card from the device.
      Ask FixBot
    2. Panasonic Lumix DMC-TZ5 button board Replacement: step 2, image 1 of 1
      • Remove 4 screws from the right side of the camera.
      • There are two 3.4mm screws at the top.
      • There are two 2.2mm screws at the bottom.
      Ask FixBot
    3. Panasonic Lumix DMC-TZ5 button board Replacement: step 3, image 1 of 1
      • Remove the single 3.4mm screw on the left side of the camera.
      Ask FixBot
    4. Panasonic Lumix DMC-TZ5 button board Replacement: step 4, image 1 of 1
      • Remove 5 screws from the base of the camera.
      • There are two 2.2mm screws next to the battery compartment.
      • There are three 4mm screws around the tripod mount.
      Ask FixBot
    5. Panasonic Lumix DMC-TZ5 button board Replacement: step 5, image 1 of 1
      • Slowly slide the back cover away from the device
      • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
      Ask FixBot
    6. Panasonic Lumix DMC-TZ5 button board Replacement: step 6, image 1 of 2 Panasonic Lumix DMC-TZ5 button board Replacement: step 6, image 2 of 2
      • Detach both ribbon cables using a spudger.
      • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
      Ask FixBot
    7. Panasonic Lumix DMC-TZ5 button board Replacement: step 7, image 1 of 1
      • Remove the back casing from the camera.
      Ask FixBot
    1. Panasonic Lumix DMC-TZ5 button board Replacement, button board: step 8, image 1 of 2 Panasonic Lumix DMC-TZ5 button board Replacement, button board: step 8, image 2 of 2
      • Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip.
      • Carefully remove the function switch cover. This unit snaps on and off.
      Ask FixBot
    2. Panasonic Lumix DMC-TZ5 button board Replacement: step 9, image 1 of 1
      • Carefully unsnap the front logic board from the rear logic board using a spudger.
      Ask FixBot
    3. Panasonic Lumix DMC-TZ5 button board Replacement: step 10, image 1 of 2 Panasonic Lumix DMC-TZ5 button board Replacement: step 10, image 2 of 2
      • Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
      Ask FixBot
    4. Panasonic Lumix DMC-TZ5 button board Replacement: step 11, image 1 of 3 Panasonic Lumix DMC-TZ5 button board Replacement: step 11, image 2 of 3 Panasonic Lumix DMC-TZ5 button board Replacement: step 11, image 3 of 3
      • This step is only necessary if you want to separate the upper part from the button board.
      • Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger.
      • This leaves you with the logic board and the top connection panel separate and free from the camera
      Ask FixBot
Ben Canfield
424 Reputation
3 Guides authored
Cal Poly, Team 9-21, Regan Fall 2010 Member of Cal Poly, Team 9-21, Regan Fall 2010
CPSU-REGAN-F10S9G21
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 66
All Time: 6,374
