Panasonic Lumix DMC-GF2 Back Cover Replacement
Views: 2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
97
All Time:
1,999
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide requires the use of a screw driver and close attention to which screws need to be removed. While following these steps, be careful not to rip out the blue and yellow ZIF ribbons that attach the back cover to the camera.
Tools
    1. Panasonic Lumix DMC-GF2 Back Cover Replacement, Battery: step 1, image 1 of 1
      • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
      Ask FixBot
    2. Panasonic Lumix DMC-GF2 Back Cover Replacement: step 2, image 1 of 2 Panasonic Lumix DMC-GF2 Back Cover Replacement: step 2, image 2 of 2
      • Push the small black tab that holds the battery with your finger to release the battery.
      • Use your fingers to pull the battery out of the camera.
      Ask FixBot
    1. Panasonic Lumix DMC-GF2 Back Cover Replacement, Back Cover: step 3, image 1 of 3 Panasonic Lumix DMC-GF2 Back Cover Replacement, Back Cover: step 3, image 2 of 3 Panasonic Lumix DMC-GF2 Back Cover Replacement, Back Cover: step 3, image 3 of 3
      • Using a Phillips #00 screwdriver, remove six 2.69mm, silver screws located on the two short sides of the camera and the bottom side.
      Ask FixBot
    2. Panasonic Lumix DMC-GF2 Back Cover Replacement: step 4, image 1 of 3 Panasonic Lumix DMC-GF2 Back Cover Replacement: step 4, image 2 of 3 Panasonic Lumix DMC-GF2 Back Cover Replacement: step 4, image 3 of 3
      • Gently lift up the back cover to access the ZIF connectors for the blue and yellow ribbons.
      • To unlock the ZIF connectors, gently push the black portion of the lock from a flat position to an upright position using a spudger.
      • Take caution not to rip the ribbons out of the ZIF connectors when lifting the back panel.
      Ask FixBot
    3. Panasonic Lumix DMC-GF2 Back Cover Replacement: step 5, image 1 of 1
      • Gently push the blue and yellow ribbons out of the unlocked ZIF connectors using your fingers.
      Ask FixBot
    4. Panasonic Lumix DMC-GF2 Back Cover Replacement: step 6, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the 3.5 mm silver screw from the upper left hand corner of the back cover.
      Ask FixBot
    5. Panasonic Lumix DMC-GF2 Back Cover Replacement: step 7, image 1 of 1
      • Using a spudger, lift up and remove the plastic cover piece from the back cover.
      • Plastic cover may fall off without prying.
      Ask FixBot
    6. Panasonic Lumix DMC-GF2 Back Cover Replacement: step 8, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the 2.69 mm silver screw located beneath the plastic piece that was previously removed.
      Ask FixBot
    7. Panasonic Lumix DMC-GF2 Back Cover Replacement: step 9, image 1 of 1
      • Using a spudger, lift up and separate the heavier metal cover from the light, plastic back cover.
      • Metal cover may fall off without prying.
      Ask FixBot
Kingsley East
474 Reputation
4 Guides authored
Baylor, Team 5-9, Williams Fall 2016 Member of Baylor, Team 5-9, Williams Fall 2016
BU-WILLIAMS-F16S5G9
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 97
All Time: 1,999
