Panasonic Lumix DMC-G5 LCD Replacement
  1. Panasonic Lumix DMC-G5 LCD Replacement, LCD: step 1, image 1 of 2 Panasonic Lumix DMC-G5 LCD Replacement, LCD: step 1, image 2 of 2
    • Use J0 screwdriver to remove the two 3.2 mm screws from the outside of the assembly.
    • Use the J0 screwsdriver to remove the two 5.6 mm screws from the inside of the face near the swivel.
    • Rotate the face to more easily gain access to the screws.
    Ask FixBot
  2. Panasonic Lumix DMC-G5 LCD Replacement: step 2, image 1 of 2 Panasonic Lumix DMC-G5 LCD Replacement: step 2, image 2 of 2
    • Slide the wide plastic opening tool underneath the crack of the side of the face and separate the components.
    Ask FixBot
  3. Panasonic Lumix DMC-G5 LCD Replacement: step 3, image 1 of 1
    • Carefully remove the filament connections from the LCD backing by lifting the black lever up first on the connector, then pulling gently outward from the LCD backing with your fingers.
    • Replace the filament connections into the backing of the new LCD face to complete replacement..
    Ask FixBot
Gabriel Gonzalez Jr
325 Reputation
3 Guides authored
USF Tampa, Team 1-3, Kass Spring 2017 Member of USF Tampa, Team 1-3, Kass Spring 2017
USFT-KASS-S17S1G3
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 30
All Time: 2,692
