Panasonic Lumix DMC-FX37 Disassembly
Views: 1.9K
View statistics:
Past 24 Hours:
0
Past 7 Days:
21
Past 30 Days:
97
All Time:
1,891
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If you have not disassembled a device similar to this in the past, here are a few tips:
1) Always place the screws you remove with their respective slots, this will prevent you from trying to insert a screw that is too big and causing internal damage. (A magnetic mat can help with this!)
2) Because this is a smaller device and you will be interacting with some of the circuit boards directly, you may wish to wear an anti-static wrist wrap to prevent damage.
3) Ribbon cables (named due to their shape) are quite delicate and should be handled gently if possible. We will be sure to warn you when dealing with these.
Otherwise, this guide will mainly be unscrewing screws.
Tools
  • Spudger
    4.9
  • Phillips #000 Screwdriver
    4.9
    1. Panasonic Lumix DMC-FX37 Disassembly, Panasonic Lumix DMC-FX37 Disassembly: step 1, image 1 of 2 Panasonic Lumix DMC-FX37 Disassembly, Panasonic Lumix DMC-FX37 Disassembly: step 1, image 2 of 2
      • Remove both of the 3 mm screws on the bottom of the camera connected to the side panel.
      Ask FixBot
    2. Panasonic Lumix DMC-FX37 Disassembly: step 2, image 1 of 2 Panasonic Lumix DMC-FX37 Disassembly: step 2, image 2 of 2
      • Remove the remaining 3 mm screw holding on the side panel and remove the panel entirely.
      Ask FixBot
    3. Panasonic Lumix DMC-FX37 Disassembly: step 3, image 1 of 2 Panasonic Lumix DMC-FX37 Disassembly: step 3, image 2 of 2
      • On the opposite side of the camera, remove the two 3 mm screws.
      • Remove the bottom side panel and place it with its respective 3 mm screw.
      Ask FixBot
    4. Panasonic Lumix DMC-FX37 Disassembly: step 4, image 1 of 3 Panasonic Lumix DMC-FX37 Disassembly: step 4, image 2 of 3 Panasonic Lumix DMC-FX37 Disassembly: step 4, image 3 of 3
      • Remove the front panel (the panel around the lens casing) from the camera.
      • Remove the two ribbon cables connected to the back panel (the panel this the LCD screen) by lifting up on their respective tabs and gently pulling out the cord.
      • Caution: When removing the back panel, the two ribbon cables are relatively delicate and must both be disconnected before the panel can be entirely removed.
      • Remove the back panel from the camera.
      Ask FixBot
    5. Panasonic Lumix DMC-FX37 Disassembly: step 5, image 1 of 1
      • Remove the top control panel (connected to the flash battery) from the camera.
      • The top control panel is connected to the rest of the camera by a delicate multi-pin plug. Be careful as to not bend the pins!
      Ask FixBot
Jackson O'DOnnell
283 Reputation
1 Guide authored
Baylor, Team S2-G3, Johnson Spring 2018 Member of Baylor, Team S2-G3, Johnson Spring 2018
BU-JOHNSON-S18S2G3
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 21
Past 30 Days: 97
All Time: 1,891
