Panasonic Lumix DMC-FX07 Flash Assembly Replacement
  1. Panasonic Lumix DMC-FX07 Flash Assembly Replacement, Battery: step 1, image 1 of 1
    • Move the switch on the battery door to the Open position.
    • The door will automatically swing open after you let it go.
    Ask FixBot
  2. Panasonic Lumix DMC-FX07 Flash Assembly Replacement: step 2, image 1 of 2 Panasonic Lumix DMC-FX07 Flash Assembly Replacement: step 2, image 2 of 2
    • Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
    • Keep your finger clear of the battery when it pops out.
    Ask FixBot
  3. Panasonic Lumix DMC-FX07 Flash Assembly Replacement, Memory Card: step 3, image 1 of 1
    • Push the memory card in and let go.
    • The memory card will pop out slightly.
    • Pull out the memory card.
    Ask FixBot
  4. Panasonic Lumix DMC-FX07 Flash Assembly Replacement, Back Cover: step 4, image 1 of 2 Panasonic Lumix DMC-FX07 Flash Assembly Replacement, Back Cover: step 4, image 2 of 2
    • Unscrew the small screws on the sides of the camera.
    • The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
    Ask FixBot
  5. Panasonic Lumix DMC-FX07 Flash Assembly Replacement: step 5, image 1 of 2 Panasonic Lumix DMC-FX07 Flash Assembly Replacement: step 5, image 2 of 2
    • Unscrew the three small screws on the bottom(#00P, 3.3mm).
    • The bottom will fall off.
    Ask FixBot
  6. Panasonic Lumix DMC-FX07 Flash Assembly Replacement: step 6, image 1 of 3 Panasonic Lumix DMC-FX07 Flash Assembly Replacement: step 6, image 2 of 3 Panasonic Lumix DMC-FX07 Flash Assembly Replacement: step 6, image 3 of 3
    • Lift up the bottom back cover by prying the bottom edge with the spudger.
    • Gently lift up the back cover with your hand from the bottom to the top.
    Ask FixBot
  7. Panasonic Lumix DMC-FX07 Flash Assembly Replacement: step 7, image 1 of 3 Panasonic Lumix DMC-FX07 Flash Assembly Replacement: step 7, image 2 of 3 Panasonic Lumix DMC-FX07 Flash Assembly Replacement: step 7, image 3 of 3
    • Lift the tabs on the ZIF connectors.
    • The ribbon cables should easily come out of the ZIF connectors.
    Ask FixBot
  8. Panasonic Lumix DMC-FX07 Flash Assembly Replacement, Top Cover: step 8, image 1 of 2 Panasonic Lumix DMC-FX07 Flash Assembly Replacement, Top Cover: step 8, image 2 of 2
    • Using the spudger, pry off the top cover by gliding the spudger along the entire edge between the top cover and the front cover.
    • Be careful not to damage the cylindrical capacitor on the circuit board under the top cover.
    Ask FixBot
  9. Panasonic Lumix DMC-FX07 Flash Assembly Replacement, Flash Assembly: step 9, image 1 of 1
    • Unscrew the small screws beneath the top cover(#00P, 1.7mm).
    Ask FixBot
  10. Panasonic Lumix DMC-FX07 Flash Assembly Replacement: step 10, image 1 of 3 Panasonic Lumix DMC-FX07 Flash Assembly Replacement: step 10, image 2 of 3 Panasonic Lumix DMC-FX07 Flash Assembly Replacement: step 10, image 3 of 3
    • Lift the logic board out with your hand by pushing the tabs out and pulling the logic board up.
    • The on/off switch and the anti-shake button may fall out.
    Ask FixBot
  11. Panasonic Lumix DMC-FX07 Flash Assembly Replacement: step 11, image 1 of 1
    • The flash assembly is hardwired into the top circuit board.
    Ask FixBot
Karissa
71 Reputation
8 Guides authored
Cal Poly, Team 6-23, Amido Spring 2012 Member of Cal Poly, Team 6-23, Amido Spring 2012
CPSU-AMIDO-S12S6G23
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 29
All Time: 1,089
