Panasonic Lumix DMC-FX01 Lens Assembly Replacement
Views: 10K
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
113
All Time:
10,485
Comments: 2
2 comments on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide will be useful for anyone who wants to replace a broken or damaged Panasonic Lumix DMC-FX01 lens assembly.
Tools
    1. Panasonic Lumix DMC-FX01 Lens Assembly Replacement, Battery: step 1, image 1 of 1
      • Locate the memory card and battery card latch on the bottom of the camera.
      • Slide the latch to the open position.
      Ask FixBot
    2. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: step 2, image 1 of 1
      • Open the battery latch, and slide the battery release lever to the right.
      Ask FixBot
    3. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: step 3, image 1 of 1
      • Remove the battery from the camera.
      Ask FixBot
    1. Panasonic Lumix DMC-FX01 Lens Assembly Replacement, Rear Casing: step 4, image 1 of 1
      • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
      Ask FixBot
    2. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: step 5, image 1 of 1
      • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
      Ask FixBot
    3. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: step 6, image 1 of 2 Panasonic Lumix DMC-FX01 Lens Assembly Replacement: step 6, image 2 of 2
      • Remove the left side casing.
      Ask FixBot
    4. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: step 7, image 1 of 1
      • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
      Ask FixBot
    5. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: step 8, image 1 of 1
      • Remove the bottom right panel.
      Ask FixBot
    6. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: step 9, image 1 of 2 Panasonic Lumix DMC-FX01 Lens Assembly Replacement: step 9, image 2 of 2
      • Gently remove the back casing.
      • Start at the bottom and carefully pry towards the top to get this piece free.
      Ask FixBot
    1. Panasonic Lumix DMC-FX01 Lens Assembly Replacement, LCD Screen: step 10, image 1 of 1
      • Gently lift up the LCD screen.
      • Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
      • It should fall out on its own or with a gentle tug.
      Ask FixBot
    2. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: step 11, image 1 of 1
      • Gently tug the thicker ribbon to remove it from its housing.
      Ask FixBot
    1. Panasonic Lumix DMC-FX01 Lens Assembly Replacement, Front Casing: step 12, image 1 of 2 Panasonic Lumix DMC-FX01 Lens Assembly Replacement, Front Casing: step 12, image 2 of 2
      • Remove the two black 5.4 mm screws that hold in the front faceplate using a Phillips #00 screwdriver.
      • There may be a third screw the the right of the lens assembly.
      Ask FixBot
    2. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: step 13, image 1 of 3 Panasonic Lumix DMC-FX01 Lens Assembly Replacement: step 13, image 2 of 3 Panasonic Lumix DMC-FX01 Lens Assembly Replacement: step 13, image 3 of 3
      • Carefully remove the upper assembly, which houses the buttons and the flash battery.
      Ask FixBot
    3. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: step 14, image 1 of 1
      • Carefully remove the front casing after verifying that the thin plastic around the lens is not still attached.
      Ask FixBot
    1. Panasonic Lumix DMC-FX01 Lens Assembly Replacement, Lens Assembly: step 15, image 1 of 2 Panasonic Lumix DMC-FX01 Lens Assembly Replacement, Lens Assembly: step 15, image 2 of 2
      • Remove the three black 5mm screws attached to the lens frame.
      Ask FixBot
    2. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: step 16, image 1 of 1
      • Remove the lens frame.
      Ask FixBot
    3. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: step 17, image 1 of 1
      • Lift out the circuit board as shown.
      Ask FixBot
    4. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: step 18, image 1 of 2 Panasonic Lumix DMC-FX01 Lens Assembly Replacement: step 18, image 2 of 2
      • Lift the two black latches that hold the connector ribbons in place.
      • Disconnect the two ribbons.
      Ask FixBot
    5. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: step 19, image 1 of 1
      • Remove the lens assembly as shown.
      Ask FixBot
5 other people completed this guide.
Steven
108 Reputation
2 Guides authored
Cal Poly, Team 9-22, Regan Fall 2010 Member of Cal Poly, Team 9-22, Regan Fall 2010
CPSU-REGAN-F10S9G22
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 113
All Time: 10,485
