Panasonic Lumix DMC-FX01 Camera Lens Replacement
    1. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Battery: step 1, image 1 of 1
      • Locate the memory card and battery card latch on the bottom of the camera.
      • Slide the latch to the open position.
      Ask FixBot
    2. Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 2, image 1 of 1
      • Open the battery latch, and slide the battery release lever to the right.
      Ask FixBot
    3. Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 3, image 1 of 1
      • Remove the battery from the camera.
      Ask FixBot
    1. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Rear Casing: step 4, image 1 of 1
      • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
      Ask FixBot
    2. Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 5, image 1 of 1
      • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
      Ask FixBot
    3. Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 6, image 1 of 2 Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 6, image 2 of 2
      • Remove the left side casing.
      Ask FixBot
    4. Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 7, image 1 of 1
      • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
      Ask FixBot
    5. Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 8, image 1 of 1
      • Remove the bottom right panel.
      Ask FixBot
    6. Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 9, image 1 of 2 Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 9, image 2 of 2
      • Gently remove the back casing.
      • Start at the bottom and carefully pry towards the top to get this piece free.
      Ask FixBot
    1. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Front Casing: step 10, image 1 of 2 Panasonic Lumix DMC-FX01 Camera Lens Replacement, Front Casing: step 10, image 2 of 2
      • Remove the two black 5.4 mm screws that hold in the front faceplate using a Phillips #00 screwdriver.
      • There may be a third screw the the right of the lens assembly.
      Ask FixBot
    2. Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 11, image 1 of 3 Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 11, image 2 of 3 Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 11, image 3 of 3
      • Carefully remove the upper assembly, which houses the buttons and the flash battery.
      Ask FixBot
    3. Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 12, image 1 of 1
      • Carefully remove the front casing after verifying that the thin plastic around the lens is not still attached.
      Ask FixBot
    1. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Lens Assembly: step 13, image 1 of 2 Panasonic Lumix DMC-FX01 Camera Lens Replacement, Lens Assembly: step 13, image 2 of 2
      • Remove the three black 5mm screws attached to the lens frame.
      Ask FixBot
    2. Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 14, image 1 of 1
      • Remove the lens frame.
      Ask FixBot
    3. Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 15, image 1 of 1
      • Lift out the circuit board as shown.
      Ask FixBot
    4. Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 16, image 1 of 2 Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 16, image 2 of 2
      • Lift the two black latches that hold the connector ribbons in place.
      • Disconnect the two ribbons.
      Ask FixBot
    5. Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 17, image 1 of 1
      • Remove the lens assembly as shown.
      Ask FixBot
    1. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Camera Lens: step 18, image 1 of 1
      • Remove four 4 mm screws from the lens assembly using the Phillips #00 screwdriver.
      Ask FixBot
    2. Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 19, image 1 of 2 Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 19, image 2 of 2
      • Separate the fixed frame unit from the main lens assembly.
      • Separate the direct frame unit from the main lens assembly.
      Ask FixBot
    3. Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 20, image 1 of 1
      • Remove the first lens frame from the lens assembly.
      Ask FixBot
    4. Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 21, image 1 of 1
      • Detach the second frame unit from the lens assembly.
      Ask FixBot
    5. Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 22, image 1 of 1
      • Remove the 4m m screw from the lens housing using the Phillips #00 screwdriver.
      Ask FixBot
    6. Panasonic Lumix DMC-FX01 Camera Lens Replacement: step 23, image 1 of 1
      • Separate the lens housing.
      • Replace the lens by gently prying away from the assembly.
      Ask FixBot
4 other people completed this guide.
Caleb Fink
191 Reputation
2 Guides authored
Cal Poly, Team 9-22, Regan Fall 2010 Member of Cal Poly, Team 9-22, Regan Fall 2010
CPSU-REGAN-F10S9G22
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 36
Past 30 Days: 72
All Time: 13,746
