Panasonic Lumix DMC-FH20 Memory Card Replacement
  1. Panasonic Lumix DMC-FH20 Memory Card Replacement, Memory Card: step 1, image 1 of 3 Panasonic Lumix DMC-FH20 Memory Card Replacement, Memory Card: step 1, image 2 of 3 Panasonic Lumix DMC-FH20 Memory Card Replacement, Memory Card: step 1, image 3 of 3
    • On the bottom of the camera, move the gray switch that has the words "open" and "lock" above it to the open position. The case will open.
    Ask FixBot
  2. Panasonic Lumix DMC-FH20 Memory Card Replacement: step 2, image 1 of 1
    • Once the case is open, you will see your memory card in the marked slot. Push the card down until you hear a small click. The card will then pop out and you will be able to remove it.
    Ask FixBot
Arianna Boushell
653 Reputation
5 Guides authored
Cal Poly, Team 10-7, Banghart Winter 2017 Member of Cal Poly, Team 10-7, Banghart Winter 2017
CPSU-BANGHART-W17S10G7
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 26
All Time: 778
