Panasonic Lumix DMC-FH20 Lens Replacement
  1. Panasonic Lumix DMC-FH20 Lens Replacement, Lens: step 1, image 1 of 3 Panasonic Lumix DMC-FH20 Lens Replacement, Lens: step 1, image 2 of 3 Panasonic Lumix DMC-FH20 Lens Replacement, Lens: step 1, image 3 of 3
    • Remove all screws (Phillips #000 head) from the sides and bottom of the camera.
    Ask FixBot
  2. Panasonic Lumix DMC-FH20 Lens Replacement: step 2, image 1 of 2 Panasonic Lumix DMC-FH20 Lens Replacement: step 2, image 2 of 2
    • Remove the back panel. This might require some extra force. If you still can't get the panel off, try to use a plastic opening tool.
    Ask FixBot
  3. Panasonic Lumix DMC-FH20 Lens Replacement: step 3, image 1 of 2 Panasonic Lumix DMC-FH20 Lens Replacement: step 3, image 2 of 2
    • Remove the circuit board. You should be able to do this with your fingers. Just grab it and pull upwards. If it does not come, use a plastic opening tool to help.
    Ask FixBot
  4. Panasonic Lumix DMC-FH20 Lens Replacement: step 4, image 1 of 2 Panasonic Lumix DMC-FH20 Lens Replacement: step 4, image 2 of 2
    • Remove the white plastic cover. This may take some extra force. You will want to try to remove from the bottom side first and peel up.
    • Then, where the silver switch is located, it will slide directly out at the top.
    Ask FixBot
  5. Panasonic Lumix DMC-FH20 Lens Replacement: step 5, image 1 of 3 Panasonic Lumix DMC-FH20 Lens Replacement: step 5, image 2 of 3 Panasonic Lumix DMC-FH20 Lens Replacement: step 5, image 3 of 3
    • Unscrew one screw (Phillips #000 head)
    • Remove the screen. You will want to use a plastic opening tool to complete this step. Pop the thin black piece of plastic upwards with the opening tool to unlock the plastic film ribbon.
    • Once unlocked, you will be able to pull the ribbon out and remove the screen completely.
    Ask FixBot
  6. Panasonic Lumix DMC-FH20 Lens Replacement: step 6, image 1 of 3 Panasonic Lumix DMC-FH20 Lens Replacement: step 6, image 2 of 3 Panasonic Lumix DMC-FH20 Lens Replacement: step 6, image 3 of 3
    • Remove the grey panel.
    • You will need to unscrew three screws (Phillips #000 head) in order to remove the panel.
    Ask FixBot
  7. Panasonic Lumix DMC-FH20 Lens Replacement: step 7, image 1 of 3 Panasonic Lumix DMC-FH20 Lens Replacement: step 7, image 2 of 3 Panasonic Lumix DMC-FH20 Lens Replacement: step 7, image 3 of 3
    • Pop the two thin black pieces of plastic upwards with the opening tool to unlock the plastic film ribbons.
    • Once unlocked, you will need to unscrew six more screws (Phillips #000 head) to completely detach the lens from the rest of the camera.
    Ask FixBot
  8. Panasonic Lumix DMC-FH20 Lens Replacement: step 8, image 1 of 2 Panasonic Lumix DMC-FH20 Lens Replacement: step 8, image 2 of 2
    • Remove the lens from the camera carefully. You can do this simply by grabbing it with your fingers and pulling out gently.
    Ask FixBot
Arianna Boushell
653 Reputation
5 Guides authored
Cal Poly, Team 10-7, Banghart Winter 2017 Member of Cal Poly, Team 10-7, Banghart Winter 2017
CPSU-BANGHART-W17S10G7
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 38
All Time: 1,661
