Panasonic KX-TGE233 Power Port Replacement
  1. Panasonic KX-TGE233 Power Port Replacement, Base Front Panel Assembly: step 1, image 1 of 1
    • To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
    Ask FixBot
  2. Panasonic KX-TGE233 Power Port Replacement: step 2, image 1 of 1
    • To start, we'll need to work with objects on the bottom of the device, so begin by flipping the device over.
    Ask FixBot
  3. Panasonic KX-TGE233 Power Port Replacement: step 3, image 1 of 1
    • To open the main docking station, you'll need to remove four 11 mm Philips #0 screws.
    Ask FixBot
  4. Panasonic KX-TGE233 Power Port Replacement: step 4, image 1 of 1
    • With the screws removed, you can use a spudger to aid in removing the back from the device.
    • Levering the back by the spudger may break the tool!
    Ask FixBot
  5. Panasonic KX-TGE233 Power Port Replacement: step 5, image 1 of 1
    • With the back removed, we now have direct access to all other components in the main docking station.
    Ask FixBot
  6. Panasonic KX-TGE233 Power Port Replacement, Power Port: step 6, image 1 of 1
    • Now that the device has been opened, the power port can easily be removed from its resting point.
    Ask FixBot
  7. Panasonic KX-TGE233 Power Port Replacement: step 7, image 1 of 1
    Ask FixBot
  8. Panasonic KX-TGE233 Power Port Replacement: step 8, image 1 of 1
    • The faulty power port can now be detached from the device from its contact points. If soldering has been successful, removal should require minimal effort.
    Ask FixBot
Nico Cruz
249 Reputation
2 Guides authored
IUPUI, Team 2-2, Baechle Spring 2016 Member of IUPUI, Team 2-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G2
5 Members
22 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 42
All Time: 2,853
