Panasonic KX-TGA410C Keypad Replacement
    1. Panasonic KX-TGA410C Keypad Replacement, Keypad: step 1, image 1 of 3 Panasonic KX-TGA410C Keypad Replacement, Keypad: step 1, image 2 of 3 Panasonic KX-TGA410C Keypad Replacement, Keypad: step 1, image 3 of 3
      • Slide the battery cover in a downwards motion to uncover the batteries.
      • Use the indentation on the case.
      Ask FixBot
    2. Panasonic KX-TGA410C Keypad Replacement: step 2, image 1 of 1
      • Remove the batteries by pulling them forward.
      Ask FixBot
    3. Panasonic KX-TGA410C Keypad Replacement: step 3, image 1 of 3 Panasonic KX-TGA410C Keypad Replacement: step 3, image 2 of 3 Panasonic KX-TGA410C Keypad Replacement: step 3, image 3 of 3
      • Use a Phillips #00 screwdriver and remove two 6.4 mm screws.
      • The screws are at the bottom right and left-hand corner.
      Ask FixBot
    4. Panasonic KX-TGA410C Keypad Replacement: step 4, image 1 of 2 Panasonic KX-TGA410C Keypad Replacement: step 4, image 2 of 2
      • Take an opening tool or pick and slide it in between the back and front cover all the way around the phone, then pull the back case off.
      Ask FixBot
    5. Panasonic KX-TGA410C Keypad Replacement: step 5, image 1 of 1
      • Use a Phillips #00 screwdriver to remove one 6.4 mm screw from the top left corner of the phone.
      Ask FixBot
    6. Panasonic KX-TGA410C Keypad Replacement: step 6, image 1 of 1
      • Gently pull the circuit board back.
      Ask FixBot
    7. Panasonic KX-TGA410C Keypad Replacement: step 7, image 1 of 1
      • Pull the button pad out.
      Ask FixBot
3 other people completed this guide.
Mumtaaz Mohamoud
217 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 29
All Time: 976
