Panasonic KX-TG6641 Base Display Screen Replacement
  1. Panasonic KX-TG6641 Base Display Screen Replacement, Base Display Screen: step 1, image 1 of 1
    • Use a Phillips #0 screwdriver to remove five screws from the back cover.
    Ask FixBot
  2. Panasonic KX-TG6641 Base Display Screen Replacement: step 2, image 1 of 1
    • To remove the back cover, use an iFixit opening tool and wedge the tool in between the loosened back charging case and the front plate.
    • Wiggle to loosen, be careful to not pry too hard as it could cause damage.
    Ask FixBot
  3. Panasonic KX-TG6641 Base Display Screen Replacement: step 3, image 1 of 2 Panasonic KX-TG6641 Base Display Screen Replacement: step 3, image 2 of 2
    • To access the display screen, use a Phillips #0 screwdriver to remove the screw on the bottom right corner of the electrical panel.
    • Unclip the wires hooked into the base.
    • It's not necessary to desolder the wires.
    Ask FixBot
  4. Panasonic KX-TG6641 Base Display Screen Replacement: step 4, image 1 of 1
    • Disconnect the two phone cable connectors.
    • Use a Phillips #0 to remove the screw that is fixed in the plastic holder for the connectors.
    Ask FixBot
  5. Panasonic KX-TG6641 Base Display Screen Replacement: step 5, image 1 of 2 Panasonic KX-TG6641 Base Display Screen Replacement: step 5, image 2 of 2
    • Move the electrical panel to the side.
    • Use a Phillips #0 to remove the four screws from the brown board and lift it to access the display screen.
    • Be aware, there is a screw under the control panel, it is indicated with the central red circle.
    Ask FixBot
  6. Panasonic KX-TG6641 Base Display Screen Replacement: step 6, image 1 of 1
    • Remove the current display screen from the electric panel.
    • Follow this process in reverse to replace the new display screen in its place.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 32
All Time: 704
