Panasonic KX-E603 Printwheel Replacement
    1. Panasonic KX-E603 Printwheel Replacement, Ink Cartridge: step 1, image 1 of 2 Panasonic KX-E603 Printwheel Replacement, Ink Cartridge: step 1, image 2 of 2
      • Open the lid of the typewriter.
      Ask FixBot
    2. Panasonic KX-E603 Printwheel Replacement: step 2, image 1 of 2 Panasonic KX-E603 Printwheel Replacement: step 2, image 2 of 2
      • To release the green locking lever, pull it towards you.
      Ask FixBot
    3. Panasonic KX-E603 Printwheel Replacement: step 3, image 1 of 2 Panasonic KX-E603 Printwheel Replacement: step 3, image 2 of 2
      • Gently lift to remove the old ink cartridge.
      Ask FixBot
    1. Panasonic KX-E603 Printwheel Replacement, Printwheel: step 4, image 1 of 2 Panasonic KX-E603 Printwheel Replacement, Printwheel: step 4, image 2 of 2
      • Firmly grasp either one, or both of the plastic printwheel ends protruding from the carriage as seen.
      • Gently lift the printwheel while slightly pushing forward to remove the printwheel from its housing.
      Ask FixBot
To reassemble your device, follow these steps in reverse using your new printwheel.
Lindsay Stratis
491 Reputation
4 Guides authored
Cal Poly, Team 17-1, Forte Spring 2015 Member of Cal Poly, Team 17-1, Forte Spring 2015
CPSU-FORTE-S15S17G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 8
Past 30 Days: 21
All Time: 757
