Panasonic KX-E603 Case Replacement
    1. Panasonic KX-E603 Case Replacement, Case: step 1, image 1 of 2 Panasonic KX-E603 Case Replacement, Case: step 1, image 2 of 2
      • Flip the typewriter to expose the bottom body panel.
      • Be careful to not damage the top surface of the typewriter when you rest it upside-down.
      Ask FixBot
    2. Panasonic KX-E603 Case Replacement: step 2, image 1 of 1
      • Remove the three 19 mm screws located in the recessed holes on the edge of the black underside panel using a Phillips #2 screwdriver.
      Ask FixBot
    3. Panasonic KX-E603 Case Replacement: step 3, image 1 of 1
      • Flip the typewriter back to its original orientation, then rotate it so that the rear is facing towards you.
      • Remove the three 19 mm screws near the bottom of the tan body panel using a Phillips #2 screwdriver.
      Ask FixBot
    4. Panasonic KX-E603 Case Replacement: step 4, image 1 of 2 Panasonic KX-E603 Case Replacement: step 4, image 2 of 2
      • Open the typewriter lid and push the carriage away to expose the two screws holding the case to the chassis.
      • Remove the two 19 mm screws using a Phillips #2 screwdriver.
      Ask FixBot
    5. Panasonic KX-E603 Case Replacement: step 5, image 1 of 2 Panasonic KX-E603 Case Replacement: step 5, image 2 of 2
      • Flip the plastic lever on the right side of the roller wheel to disengage the paper lock.
      Ask FixBot
    6. Panasonic KX-E603 Case Replacement: step 6, image 1 of 3 Panasonic KX-E603 Case Replacement: step 6, image 2 of 3 Panasonic KX-E603 Case Replacement: step 6, image 3 of 3
      • Remove the roller wheel adjustment knobs by pulling firmly outward.
      • Both black knobs must be removed in this step.
      Ask FixBot
    7. Panasonic KX-E603 Case Replacement: step 7, image 1 of 2 Panasonic KX-E603 Case Replacement: step 7, image 2 of 2
      • Unlock the roller wheel by simultaneously pressing down on the two spring levers on the left and right of the roller ends.
      Ask FixBot
    8. Panasonic KX-E603 Case Replacement: step 8, image 1 of 2 Panasonic KX-E603 Case Replacement: step 8, image 2 of 2
      • While both spring levers are depressed, lift up with both hands to remove the roller wheel.
      Ask FixBot
    9. Panasonic KX-E603 Case Replacement: step 9, image 1 of 3 Panasonic KX-E603 Case Replacement: step 9, image 2 of 3 Panasonic KX-E603 Case Replacement: step 9, image 3 of 3
      • Flip the top down. Then, with both hands, lift straight up on the tan case to remove it from the chassis.
      Ask FixBot
2 other people completed this guide.
Matthew Callaghan
280 Reputation
1 Guide authored
Cal Poly, Team 17-1, Forte Spring 2015 Member of Cal Poly, Team 17-1, Forte Spring 2015
CPSU-FORTE-S15S17G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 34
All Time: 965
