Up to 20% off select tools
Panasonic HDC-TM90 Lens Clean
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
6
Past 30 Days:
59
All Time:
1,101
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 35 minutes
Difficulty: Difficult
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Are you noticing any dust, smudges, or debris that’s preventing you from taking clear videos on your Panasonic HDC-TM90? This guide walks you through the careful process of disassembling your camcorder to access your lens and clean it from the inside.
A clean lens is needed to optimize image quality to ensure you produce clear, sharp videos and remove any unwanted visual effects.
Be sure to power off the camcorder before beginning to repair the device.
    1. Panasonic HDC-TM90 Lens Clean, Battery: step 1, image 1 of 1
      • Open the LCD screen.
      Ask FixBot
    2. Panasonic HDC-TM90 Lens Clean: step 2, image 1 of 1
      • Slide the battery release switch away from the battery.
      Ask FixBot
    3. Panasonic HDC-TM90 Lens Clean: step 3, image 1 of 1
      • While holding the switch away from the battery, push the battery out of the slot.
      Ask FixBot
    4. Panasonic HDC-TM90 Lens Clean: step 4, image 1 of 1
      • Remove the battery from the camera.
      Ask FixBot
    1. Panasonic HDC-TM90 Lens Clean, Lens: step 5, image 1 of 3 Panasonic HDC-TM90 Lens Clean, Lens: step 5, image 2 of 3 Panasonic HDC-TM90 Lens Clean, Lens: step 5, image 3 of 3
      • Remove 5 screws from the side panel body of the camcorder.
      • Use the spudger to remove the top of the camcorder.
      Ask FixBot
    2. Panasonic HDC-TM90 Lens Clean: step 6, image 1 of 2 Panasonic HDC-TM90 Lens Clean: step 6, image 2 of 2
      • Unscrew three screws to remove the lens rim on the front of the camcorder.
      • Be aware of the wires attaching the lens rim to the body of the camcorder. You will not be able to separate the lens rim completely.
      • Use caution when separating the shutter lever.
      Ask FixBot
    3. Panasonic HDC-TM90 Lens Clean: step 7, image 1 of 1
      • Remove the rubber ring around the lens.
      Ask FixBot
    4. Panasonic HDC-TM90 Lens Clean: step 8, image 1 of 1
      • Unscrew the lens by removing the three screws connected to it.
      Ask FixBot
Author
with
Tyler Jaynes
1 Reputation
2 Guides authored
Baylor, Team 8-4, Whitney Spring 2017 Member of Baylor, Team 8-4, Whitney Spring 2017
BU-WHITNEY-S17S8G4
3 Members
48 Guides authored
1 Guide Comment
Steps 1-4: good pre-req
Step 5-bullet 1: Which screwdriver and how many screws? There seem to be a lot of screws so perhaps numbering how many and where they came from would be helpful. Maybe color coding your steps with more details using markers of how many screws and what location in the pictures would be helpful.
Step 5 bullet 1 and 2 should probably be 2 separate steps.
Step 5- bullet 2: could use a picture
Step 6: Did not seem to be how we did this step at all. Perhaps this could be explained in much more detail with more detailed pictures. Also the cautions and warnings should be labeled as such.
Rene Klopf - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 59
All Time: 1,101
