Panasonic HDC-TM90 LCD Screen Replacement
    1. Panasonic HDC-TM90 LCD Screen Replacement, Battery: step 1, image 1 of 1
      • Open the LCD screen.
      Ask FixBot
    2. Panasonic HDC-TM90 LCD Screen Replacement: step 2, image 1 of 1
      • Slide the battery release switch away from the battery.
      Ask FixBot
    3. Panasonic HDC-TM90 LCD Screen Replacement: step 3, image 1 of 1
      • While holding the switch away from the battery, push the battery out of the slot.
      Ask FixBot
    4. Panasonic HDC-TM90 LCD Screen Replacement: step 4, image 1 of 1
      • Remove the battery from the camera.
      Ask FixBot
    1. Panasonic HDC-TM90 LCD Screen Replacement, Lens: step 5, image 1 of 3 Panasonic HDC-TM90 LCD Screen Replacement, Lens: step 5, image 2 of 3 Panasonic HDC-TM90 LCD Screen Replacement, Lens: step 5, image 3 of 3
      • Remove 5 screws from the side panel body of the camcorder.
      • Use the spudger to remove the top of the camcorder.
      Ask FixBot
    2. Panasonic HDC-TM90 LCD Screen Replacement: step 6, image 1 of 2 Panasonic HDC-TM90 LCD Screen Replacement: step 6, image 2 of 2
      • Unscrew three screws to remove the lens rim on the front of the camcorder.
      • Be aware of the wires attaching the lens rim to the body of the camcorder. You will not be able to separate the lens rim completely.
      • Use caution when separating the shutter lever.
      Ask FixBot
    3. Panasonic HDC-TM90 LCD Screen Replacement: step 7, image 1 of 1
      • Remove the rubber ring around the lens.
      Ask FixBot
    4. Panasonic HDC-TM90 LCD Screen Replacement: step 8, image 1 of 1
      • Unscrew the lens by removing the three screws connected to it.
      Ask FixBot
    1. Panasonic HDC-TM90 LCD Screen Replacement, LCD Screen: step 9, image 1 of 2 Panasonic HDC-TM90 LCD Screen Replacement, LCD Screen: step 9, image 2 of 2
      • Remove the side panel of the camcorder.
      • Remove the top panel of the camcorder.
      • For help with this step see prerequisite guide: Lens Clean.
      Ask FixBot
    2. Panasonic HDC-TM90 LCD Screen Replacement: step 10, image 1 of 1
      • Open camcorder screen.
      Ask FixBot
    3. Panasonic HDC-TM90 LCD Screen Replacement: step 11, image 1 of 1
      • Turn the LCD screen perpendicular to the camcorder.
      • Remove the screws.
      • Have caution when you remove the screen. There is a wire connecting it to the rest of the camera that should not be detached.
      Ask FixBot
    4. Panasonic HDC-TM90 LCD Screen Replacement: step 12, image 1 of 1
      • Carefully pry the plastic backing on the screen using a metal spudger.
      Ask FixBot
    5. Panasonic HDC-TM90 LCD Screen Replacement: step 13, image 1 of 2 Panasonic HDC-TM90 LCD Screen Replacement: step 13, image 2 of 2
      • Peel back the black tape holding the wire strip to the camcorder screen.
      • Unclip the small latch from the wire strip.
      Ask FixBot
    6. Panasonic HDC-TM90 LCD Screen Replacement: step 14, image 1 of 1
      • Remove the screws from the metal frame.
      • Be careful when holding the screen after the frame has been unscrewed. The screen and all of its components are unattached and can fall apart.
      Ask FixBot
BayleeVersteeg
37 Reputation
2 Guides authored
Baylor, Team 8-4, Whitney Spring 2017 Member of Baylor, Team 8-4, Whitney Spring 2017
BU-WHITNEY-S17S8G4
3 Members
48 Guides authored
1 Guide Comment
Steps 1-4 are good pre-reqs.
Are all of steps 5-8 absolutely necessary for LCD screen replacement?
Step 9-bullet 3: Change to 'note' rather than bullet point and put it first.
Step 11-bullet 2: List the # of screws to be removed and with what screwdriver. Show 2nd picture of screws to remove on actual LCD door.
Step 11-bullet 3: Change to a "caution" rather than just a bullet. Also we had a spring fall out at this step with no idea where it came from. Perhaps you could address this.
Step 12- We actually had to use a 2nd spudger to pry it apart. One as a wedge and one as a lever to separate.
Step 14-bullet 2: change to a "Warning" symbol.
Seems to be an incomplete guide, as the LCD screen is still affixed to the device.
Rene Klopf - Reply Share
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 24
All Time: 893
