Panasonic HDC-TM15 Side Cover Replacement
    1. Panasonic HDC-TM15 Side Cover Replacement, Side Cover: step 1, image 1 of 1
      • Using the Phillips #00 Screwdriver, unscrew the five .5 mm Phillips #00 screws on the hand-strap side of the camcorder.
      Ask FixBot
    2. Panasonic HDC-TM15 Side Cover Replacement: step 2, image 1 of 1
      • Next, unscrew the six .5 mm Phillips #00 screws on the bottom of the camcorder.
      Ask FixBot
    3. Panasonic HDC-TM15 Side Cover Replacement: step 3, image 1 of 3 Panasonic HDC-TM15 Side Cover Replacement: step 3, image 2 of 3 Panasonic HDC-TM15 Side Cover Replacement: step 3, image 3 of 3
      • By putting your hand through the hand-strap, tug on the side cover until it comes off completely.
      • Once the old cover is completely detached, set it aside.
      • The inside of your camcorder should now be completely exposed, as seen in the photos.
      Ask FixBot
    4. Panasonic HDC-TM15 Side Cover Replacement: step 4, image 1 of 2 Panasonic HDC-TM15 Side Cover Replacement: step 4, image 2 of 2
      • Line up the new side cover in the exact same place, ensuring that the screw holes match.
      • Re-screw the side cover into place.
      Ask FixBot
    5. Panasonic HDC-TM15 Side Cover Replacement: step 5, image 1 of 1
      • Gently tug on the hand-strap to ensure that the screws are tight and the side cover is secure.
      • When the side cover is securely fastened, you have completed the side cover replacement of your Panasonic HDC-TM15 camcorder.
      Ask FixBot
Tricia Fallo
210 Reputation
2 Guides authored
Marist, Team 1-4, Laflen Spring 2015 Member of Marist, Team 1-4, Laflen Spring 2015
MARS-LAFLEN-S15S1G4
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 11
All Time: 550
