Panasonic ES2207P Battery Replacement
    1. Panasonic ES2207P Battery Replacement, Battery: step 1, image 1 of 1
      • Remove foil head and blades.
      Ask FixBot
    2. Panasonic ES2207P Battery Replacement: step 2, image 1 of 1
      • Remove (2) 7.9mm Phillips #0 screws.
      • Remove (2) 14.3mm Phillips #0 screws.
      Ask FixBot
    3. Panasonic ES2207P Battery Replacement: step 3, image 1 of 1
      • Push the blade mount assembly towards the rear of razor and remove.
      Ask FixBot
    4. Panasonic ES2207P Battery Replacement: step 4, image 1 of 1
      • Be careful not to break any tabs that hold the panels to the body.
      • Remove both external panels using spudger if necessary.
      Ask FixBot
    5. Panasonic ES2207P Battery Replacement: step 5, image 1 of 1
      Ask FixBot
    6. Panasonic ES2207P Battery Replacement: step 6, image 1 of 1
      • This step may require a fair amount of force due to the O-ring.
      • Pull to separate the end-cap from the body.
      Ask FixBot
    7. Panasonic ES2207P Battery Replacement: step 7, image 1 of 1
      • Remove (2) 7.9mm Phillips #0 screws and remove endcap from frame.
      Ask FixBot
    8. Panasonic ES2207P Battery Replacement: step 8, image 1 of 2 Panasonic ES2207P Battery Replacement: step 8, image 2 of 2
      • Push forward on the lower terminal to remove the battery from the frame.
      Ask FixBot
4 other people completed this guide.
Kevin Marvell
309 Reputation
2 Guides authored
IUPUI, Team S6-G5, Baechle Fall 2017 Member of IUPUI, Team S6-G5, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G5
3 Members
24 Guides authored
3 Guide Comments
Where to buy the battery? Can you provide more details?
Iurie Manea - Reply Share
Onde comprar bateria?
edie_engenheiro - Reply Share
super great job on the break down. Thanks
Jeff Harvey - Reply Share
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 62
All Time: 4,140
