Panasonic ER-GN30-K Motor Replacement
    1. Panasonic ER-GN30-K Motor Replacement, Motor: step 1, image 1 of 1
      • Remove the dark transparent cap by gently pulling on it.
      Ask FixBot
    2. Panasonic ER-GN30-K Motor Replacement: step 2, image 1 of 1
      • Remove the back battery cap from the device by twisting it to the unlock position and pulling.
      Ask FixBot
    3. Panasonic ER-GN30-K Motor Replacement: step 3, image 1 of 1
      • Remove the black trimmer cap from the top of the device by gently pulling it.
      Ask FixBot
    4. Panasonic ER-GN30-K Motor Replacement: step 4, image 1 of 1
      • Use a metal spudger to pry apart the silver plastic case.
      • Pull each side of the plastic case off.
      Ask FixBot
    5. Panasonic ER-GN30-K Motor Replacement: step 5, image 1 of 1
      • Unscrew one 20mm Phillips #00 screw.
      Ask FixBot
    6. Panasonic ER-GN30-K Motor Replacement: step 6, image 1 of 1
      • Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
      Ask FixBot
    7. Panasonic ER-GN30-K Motor Replacement: step 7, image 1 of 2 Panasonic ER-GN30-K Motor Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove the plastic cover of the motor shaft by pulling it away from the motor.
      Ask FixBot
    8. Panasonic ER-GN30-K Motor Replacement: step 8, image 1 of 1
      • Remove the motor from the case by sliding the cover off of it.
      Ask FixBot
6 other people completed this guide.
Corey Tappan
209 Reputation
1 Guide authored
USF Tampa, Team 15-3, Blackwell Fall 2015 Member of USF Tampa, Team 15-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G3
4 Members
60 Guides authored
2 Guide Comments
My motor working intermittently. Took apart per instruction (very detailed, thank you). Everything loos good on the internals. I think my problem is succumb build up on the negative spring where it makes contact on negative end of battery. I scrapped it a little with tip of knife, working some what better. Need to find small wire brush to get in there and give it a good cleaning. Thank you for your guide :)
Rocko the fixit cat - Reply Share
Thanks for such a detailed step by step to disassemble. It appears that the motor is not functioning: LD-050FF-2043V motor. But I was not able to find a replacement on the internet. Any suggestions?
David Freedman - Reply Share
Past 24 Hours: 10
Past 7 Days: 45
Past 30 Days: 133
All Time: 5,035
