Panasonic DP-UB150-K Laser Replacement
  1. Panasonic DP-UB150-K Laser Replacement, Open tray and pull power: step 1, image 1 of 1
    • Press the eject button to open the disc tray.
    • Unplug the power adaptor to leave the tray open.
    • Unplug any other cables.
    Ask FixBot
  2. Panasonic DP-UB150-K Laser Replacement, Remove top case: step 2, image 1 of 2 Panasonic DP-UB150-K Laser Replacement, Remove top case: step 2, image 2 of 2
    • Remove the 3 Phillips screws from the back of the case.
    • Slide the top case up and back to remove it.
    • It helps if you pull the left and right sides out a bit to clear the base.
    Ask FixBot
  3. Panasonic DP-UB150-K Laser Replacement, Remove disc tray front: step 3, image 1 of 2 Panasonic DP-UB150-K Laser Replacement, Remove disc tray front: step 3, image 2 of 2
    • Unclip the front of the disc tray.
    • Support the tray while you unclip the front.
    • It should slide up and off.
    Ask FixBot
  4. Panasonic DP-UB150-K Laser Replacement, Remove case front: step 4, image 1 of 3 Panasonic DP-UB150-K Laser Replacement, Remove case front: step 4, image 2 of 3 Panasonic DP-UB150-K Laser Replacement, Remove case front: step 4, image 3 of 3
    • Release the latches on the left and right sides plus the two underneath.
    • Slide the front off and guide it over the open disc tray.
    Ask FixBot
  5. Panasonic DP-UB150-K Laser Replacement, Loosen drive lid: step 5, image 1 of 3 Panasonic DP-UB150-K Laser Replacement, Loosen drive lid: step 5, image 2 of 3 Panasonic DP-UB150-K Laser Replacement, Loosen drive lid: step 5, image 3 of 3
    • Remove the 3 Phillips screws from the drive lid.
    • Unlatch the left and right sides.
    Ask FixBot
  6. Panasonic DP-UB150-K Laser Replacement, Remove the drive cover: step 6, image 1 of 2 Panasonic DP-UB150-K Laser Replacement, Remove the drive cover: step 6, image 2 of 2
    • Lift the drive cover slightly up at the rear.
    • Slide it back to clear the retaining slots at the front.
    Ask FixBot
  7. Panasonic DP-UB150-K Laser Replacement, Disconnect laser ribbon cable: step 7, image 1 of 3 Panasonic DP-UB150-K Laser Replacement, Disconnect laser ribbon cable: step 7, image 2 of 3 Panasonic DP-UB150-K Laser Replacement, Disconnect laser ribbon cable: step 7, image 3 of 3
    • With the drive open you should now see the laser unit mounted on rails and driven by a motor.
    • Gently open the black retaining clip on the laser unit ribbon connector.
    • Disconnect the ribbon cable.
    Ask FixBot
  8. Panasonic DP-UB150-K Laser Replacement, Unclip rails: step 8, image 1 of 3 Panasonic DP-UB150-K Laser Replacement, Unclip rails: step 8, image 2 of 3 Panasonic DP-UB150-K Laser Replacement, Unclip rails: step 8, image 3 of 3
    • Unhook the 4 spring clips holding the rails in place. There are 2 clips per rail.
    • You may need to use a screwdriver to guide the hooks free so be very careful not to damage the delicate ribbon cable.
    • With the rails free you can now lift them and the laser unit out of the drive.
    Ask FixBot
  9. Panasonic DP-UB150-K Laser Replacement, Remove laser antistatic solder points: step 9, image 1 of 3 Panasonic DP-UB150-K Laser Replacement, Remove laser antistatic solder points: step 9, image 2 of 3 Panasonic DP-UB150-K Laser Replacement, Remove laser antistatic solder points: step 9, image 3 of 3
    • My "new" laser appeared to be used so I didn't need to remove any antistatic solder points.
    • A parts catalogue (https://fixpart.co.uk/product/panasonic-...) shows solder across a couple of points on the lower right hand side of the laser.
    • If these are present on your new laser you need to remove them with a soldering iron. You may get away with just touching the iron onto them but don't be surprised if you need to use some desoldering wick.
    Ask FixBot
  10. Panasonic DP-UB150-K Laser Replacement, Transfer motor arm from old laser: step 10, image 1 of 2 Panasonic DP-UB150-K Laser Replacement, Transfer motor arm from old laser: step 10, image 2 of 2
    • Turn the old laser unit over. Remove the screw holding the white motor arm in place. Fit it to the new laser unit.
    Ask FixBot
  11. Panasonic DP-UB150-K Laser Replacement, Remount laser, rails and clips: step 11, image 1 of 3 Panasonic DP-UB150-K Laser Replacement, Remount laser, rails and clips: step 11, image 2 of 3 Panasonic DP-UB150-K Laser Replacement, Remount laser, rails and clips: step 11, image 3 of 3
    • Mount the laser on the rails. Add a spring clip to the end of each rail.
    • Insert back into the drive while making sure the white arm on the side of the laser unit engages with the worm gear.
    • Hook each of the spring clips into place. Make sure the clips are under tension and aren't loose.
    • You may need to use a screwdriver to push them into place. Be careful not to damage the ribbon cable.
    Ask FixBot
  12. Panasonic DP-UB150-K Laser Replacement, Connect laser ribbon cable: step 12, image 1 of 3 Panasonic DP-UB150-K Laser Replacement, Connect laser ribbon cable: step 12, image 2 of 3 Panasonic DP-UB150-K Laser Replacement, Connect laser ribbon cable: step 12, image 3 of 3
    • Insert the ribbon connector and make sure it is lined up and square.
    • Close the black retaining clip.
    Ask FixBot
  13. Panasonic DP-UB150-K Laser Replacement, Clean laser lens: step 13, image 1 of 1
    • Now is a good time to make sure the laser lens is clean!
    • Gently clean it with a cotton bud/Q-tip and some isopropyl alcohol.
    Ask FixBot
  14. Panasonic DP-UB150-K Laser Replacement, Refit the drive cover: step 14, image 1 of 2 Panasonic DP-UB150-K Laser Replacement, Refit the drive cover: step 14, image 2 of 2
    • Refit the drive cover by sliding the front in first to engage the retaining slots. Then lower the rear into place.
    Ask FixBot
  15. Panasonic DP-UB150-K Laser Replacement, Fasten the drive cover in place: step 15, image 1 of 3 Panasonic DP-UB150-K Laser Replacement, Fasten the drive cover in place: step 15, image 2 of 3 Panasonic DP-UB150-K Laser Replacement, Fasten the drive cover in place: step 15, image 3 of 3
    • Make sure the left and right latches are clicked into place.
    • Refit the 3 Phillips screws
    Ask FixBot
  16. Panasonic DP-UB150-K Laser Replacement, Refit case front: step 16, image 1 of 3 Panasonic DP-UB150-K Laser Replacement, Refit case front: step 16, image 2 of 3 Panasonic DP-UB150-K Laser Replacement, Refit case front: step 16, image 3 of 3
    • Slide the case front over the open drive tray.
    • Make sure the button pushers are lined up with the switches on the orange board.
    • Clip the case front in place. Latches are on the left and right sides with two underneath.
    Ask FixBot
  17. Panasonic DP-UB150-K Laser Replacement, Refit top case: step 17, image 1 of 1
    • Refit the top case.
    • Refit the 3 Phillips screws.
    Ask FixBot
Hopefully your player should now be working ok!
z80dan
266 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 72
All Time: 647
