Panasonic DMP-BD89 Wifi Board Replacement
  1. Panasonic DMP-BD89 Wifi Board Replacement, Disk Tray Cover: step 1, image 1 of 2 Panasonic DMP-BD89 Wifi Board Replacement, Disk Tray Cover: step 1, image 2 of 2
    • First, before powering off, press the eject button to open the tray.
    Ask FixBot
  2. Panasonic DMP-BD89 Wifi Board Replacement: step 2, image 1 of 3 Panasonic DMP-BD89 Wifi Board Replacement: step 2, image 2 of 3 Panasonic DMP-BD89 Wifi Board Replacement: step 2, image 3 of 3
    • Remove the front cover of the tray.
    • Do so by gently pushing it out, away from the player, ensuring the pictured tabs clear the tray.
    • Then slide it vertically up and away.
    Ask FixBot
  3. Panasonic DMP-BD89 Wifi Board Replacement: step 3, image 1 of 2 Panasonic DMP-BD89 Wifi Board Replacement: step 3, image 2 of 2
    • Press eject button to close the tray.
    • Make sure to unpower and unplug device before continue work on other fixes.
    Ask FixBot
  4. Panasonic DMP-BD89 Wifi Board Replacement, Exterior Cover: step 4, image 1 of 2 Panasonic DMP-BD89 Wifi Board Replacement, Exterior Cover: step 4, image 2 of 2
    • Using a Phillips #1 screwdriver, unscrew the back three screws.
    Ask FixBot
  5. Panasonic DMP-BD89 Wifi Board Replacement: step 5, image 1 of 1
    • Slide the top panel horizontally to remove it.
    Ask FixBot
  6. Panasonic DMP-BD89 Wifi Board Replacement: step 6, image 1 of 3 Panasonic DMP-BD89 Wifi Board Replacement: step 6, image 2 of 3 Panasonic DMP-BD89 Wifi Board Replacement: step 6, image 3 of 3
    • Locate 6 tabs across the device.
    • 2 are on the bottom, 1 is on the left and right, and 2 are are on the inside.
    Ask FixBot
  7. Panasonic DMP-BD89 Wifi Board Replacement: step 7, image 1 of 1
    • Pop the 6 markers out.
    • Then take off the cover.
    Ask FixBot
  8. Panasonic DMP-BD89 Wifi Board Replacement, Wifi Board: step 8, image 1 of 2 Panasonic DMP-BD89 Wifi Board Replacement, Wifi Board: step 8, image 2 of 2
    • Locate reddish brown cable. Detach from green circuit board by pulling upward.
    Ask FixBot
  9. Panasonic DMP-BD89 Wifi Board Replacement: step 9, image 1 of 1
    • Using tweezer, compress the white knob holding the wifi module board in place.
    Ask FixBot
  10. Panasonic DMP-BD89 Wifi Board Replacement: step 10, image 1 of 2 Panasonic DMP-BD89 Wifi Board Replacement: step 10, image 2 of 2
    • Pull the module board straight up, removing completely. The second photo is how your device should look with the WiFi board removed.
    Ask FixBot
Mohan Saxena
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 22
All Time: 721
