Panasonic DMC-FZ70 Viewfinder Replacement
    1. Panasonic DMC-FZ70 Viewfinder Replacement, Back Panel: step 1, image 1 of 2 Panasonic DMC-FZ70 Viewfinder Replacement, Back Panel: step 1, image 2 of 2
      • All screws should be removed using a Phillips #0 screwdriver.
      • Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
      Ask FixBot
    2. Panasonic DMC-FZ70 Viewfinder Replacement: step 2, image 1 of 2 Panasonic DMC-FZ70 Viewfinder Replacement: step 2, image 2 of 2
      • Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
      Ask FixBot
    3. Panasonic DMC-FZ70 Viewfinder Replacement: step 3, image 1 of 2 Panasonic DMC-FZ70 Viewfinder Replacement: step 3, image 2 of 2
      • Turn the camera upside down and unscrew the three 5mm screws found on the bottom.
      Ask FixBot
    4. Panasonic DMC-FZ70 Viewfinder Replacement: step 4, image 1 of 2 Panasonic DMC-FZ70 Viewfinder Replacement: step 4, image 2 of 2
      • On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
      • With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
      Ask FixBot
    5. Panasonic DMC-FZ70 Viewfinder Replacement: step 5, image 1 of 1
      • Proceed to remove the four 5mm Phillips screws that you just uncovered.
      Ask FixBot
    6. Panasonic DMC-FZ70 Viewfinder Replacement: step 6, image 1 of 1
      • Slowly pull on both side of the camera, until both halves begin to separate from each other.
      • Do not pull too hard, as both halves are held together with ZIF connector cables.
      Ask FixBot
    7. Panasonic DMC-FZ70 Viewfinder Replacement: step 7, image 1 of 3 Panasonic DMC-FZ70 Viewfinder Replacement: step 7, image 2 of 3 Panasonic DMC-FZ70 Viewfinder Replacement: step 7, image 3 of 3
      • Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
      • Carefully pull the ribbon cables out of the slot once they have been released.
      • Only the two indicated connectors need to be removed to separate the two halves of the camera.
      Ask FixBot
    1. Panasonic DMC-FZ70 Viewfinder Replacement, Viewfinder: step 8, image 1 of 2 Panasonic DMC-FZ70 Viewfinder Replacement, Viewfinder: step 8, image 2 of 2
      • Using a plastic opening tool, flip up the black switch on the ZIF connector that attaches the viewfinder to the motherboard.
      • Once the connector has been opened, gently pull the cable from its slot.
      Ask FixBot
    2. Panasonic DMC-FZ70 Viewfinder Replacement: step 9, image 1 of 2 Panasonic DMC-FZ70 Viewfinder Replacement: step 9, image 2 of 2
      • Holding the sides of the viewfinder, pull it out of the camera.
      • Removing the viewfinder requires a strong, yet steady pull.
      Ask FixBot
Alberto Rodriguez
537 Reputation
4 Guides authored
Cal Poly, Team 21-3, Maness Winter 2017 Member of Cal Poly, Team 21-3, Maness Winter 2017
CPSU-MANESS-W17S21G3
6 Members
72 Guides authored
1 Guide Comment
Wow, this is very HELPFUL! I saved it with Zotero in case I need it one day. I'm simply looking for an eyepiece extender and/or rubber eyepiece combo. If you have a good source Photo Supply you'd recommend, please do so.
Mr. Phil - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 29
All Time: 1,849
