Up to 20% off select tools
Panasonic DMC-FZ70 Operation Unit Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
119
All Time:
3,376
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
The Operations Unit is a panel of top of the camera that contains the mode dial, power switch, shutter button, and video-record button. If any of these buttons are missing, jammed, or no longer working, you can use this guide to learn how to replace the unit. Before you begin, make sure that the battery and SD card have been removed.
    1. Panasonic DMC-FZ70 Operation  Unit Replacement, Back Panel: step 1, image 1 of 2 Panasonic DMC-FZ70 Operation  Unit Replacement, Back Panel: step 1, image 2 of 2
      • All screws should be removed using a Phillips #0 screwdriver.
      • Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
      Ask FixBot
    2. Panasonic DMC-FZ70 Operation  Unit Replacement: step 2, image 1 of 2 Panasonic DMC-FZ70 Operation  Unit Replacement: step 2, image 2 of 2
      • Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
      Ask FixBot
    3. Panasonic DMC-FZ70 Operation  Unit Replacement: step 3, image 1 of 2 Panasonic DMC-FZ70 Operation  Unit Replacement: step 3, image 2 of 2
      • Turn the camera upside down and unscrew the three 5mm screws found on the bottom.
      Ask FixBot
    4. Panasonic DMC-FZ70 Operation  Unit Replacement: step 4, image 1 of 2 Panasonic DMC-FZ70 Operation  Unit Replacement: step 4, image 2 of 2
      • On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
      • With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
      Ask FixBot
    5. Panasonic DMC-FZ70 Operation  Unit Replacement: step 5, image 1 of 1
      • Proceed to remove the four 5mm Phillips screws that you just uncovered.
      Ask FixBot
    6. Panasonic DMC-FZ70 Operation  Unit Replacement: step 6, image 1 of 1
      • Slowly pull on both side of the camera, until both halves begin to separate from each other.
      • Do not pull too hard, as both halves are held together with ZIF connector cables.
      Ask FixBot
    7. Panasonic DMC-FZ70 Operation  Unit Replacement: step 7, image 1 of 3 Panasonic DMC-FZ70 Operation  Unit Replacement: step 7, image 2 of 3 Panasonic DMC-FZ70 Operation  Unit Replacement: step 7, image 3 of 3
      • Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
      • Carefully pull the ribbon cables out of the slot once they have been released.
      • Only the two indicated connectors need to be removed to separate the two halves of the camera.
      Ask FixBot
    1. Panasonic DMC-FZ70 Operation  Unit Replacement, Motherboard: step 8, image 1 of 1
      • Using a Torx driver, unscrew the two 5mm Phillipd screws on the motherboard
      Ask FixBot
    2. Panasonic DMC-FZ70 Operation  Unit Replacement: step 9, image 1 of 3 Panasonic DMC-FZ70 Operation  Unit Replacement: step 9, image 2 of 3 Panasonic DMC-FZ70 Operation  Unit Replacement: step 9, image 3 of 3
      • The five ribbon cables shown will need to be removed from the ZIF connectors. Using a plastic opening tool, unlock the cables by lifting the black strip on the rectangular connection socket.
      • Carefully pull each of the ribbon cables out of their sockets.
      • The cable should slide out smoothly- any significant resistance might signal that the locking lever has not yet released the cable.
      Ask FixBot
    3. Panasonic DMC-FZ70 Operation  Unit Replacement: step 10, image 1 of 2 Panasonic DMC-FZ70 Operation  Unit Replacement: step 10, image 2 of 2
      • Once the screws and the ribbon cables have been removed, lift the mother board from its slot.
      Ask FixBot
    1. Panasonic DMC-FZ70 Operation  Unit Replacement, Operation  Unit: step 11, image 1 of 2 Panasonic DMC-FZ70 Operation  Unit Replacement, Operation  Unit: step 11, image 2 of 2
      • Unscrew one 10mm Phillips screw to the right and underneath the viewfinder.
      Ask FixBot
    2. Panasonic DMC-FZ70 Operation  Unit Replacement: step 12, image 1 of 1
      • Using a plastic opening tool, flip up the switch on the ZIF connector underneath the operations unit and pull the ribbon out of the motherboard.
      Ask FixBot
    3. Panasonic DMC-FZ70 Operation  Unit Replacement: step 13, image 1 of 3 Panasonic DMC-FZ70 Operation  Unit Replacement: step 13, image 2 of 3 Panasonic DMC-FZ70 Operation  Unit Replacement: step 13, image 3 of 3
      • Slide out and replace the operation unit.
      Ask FixBot
4 other people completed this guide.
Author
with
Alberto Rodriguez
537 Reputation
4 Guides authored
Cal Poly, Team 21-3, Maness Winter 2017 Member of Cal Poly, Team 21-3, Maness Winter 2017
CPSU-MANESS-W17S21G3
6 Members
72 Guides authored
1 Guide Comment
Alberto,
Great instructions! Saved me $165 (compared to camera repair shop).
Professor Roy Hinkley - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 119
All Time: 3,376
