Up to 20% off select tools
Panasonic DMC-FZ70 Back Frame Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
91
All Time:
1,858
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to access the front frame of the camera. This is the area of the camera that contains buttons like the playback and cursor buttons, as well as the window through which you can view the LCD screen. If these buttons have come loose, or if the frame is cracked, this guide will help you replace the frame. Before you begin, make sure that the battery and SD card have been removed.
    1. Panasonic DMC-FZ70 Back Frame Replacement, Back Panel: step 1, image 1 of 2 Panasonic DMC-FZ70 Back Frame Replacement, Back Panel: step 1, image 2 of 2
      • All screws should be removed using a Phillips #0 screwdriver.
      • Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
      Ask FixBot
    2. Panasonic DMC-FZ70 Back Frame Replacement: step 2, image 1 of 2 Panasonic DMC-FZ70 Back Frame Replacement: step 2, image 2 of 2
      • Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
      Ask FixBot
    3. Panasonic DMC-FZ70 Back Frame Replacement: step 3, image 1 of 2 Panasonic DMC-FZ70 Back Frame Replacement: step 3, image 2 of 2
      • Turn the camera upside down and unscrew the three 5mm screws found on the bottom.
      Ask FixBot
    4. Panasonic DMC-FZ70 Back Frame Replacement: step 4, image 1 of 2 Panasonic DMC-FZ70 Back Frame Replacement: step 4, image 2 of 2
      • On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
      • With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
      Ask FixBot
    5. Panasonic DMC-FZ70 Back Frame Replacement: step 5, image 1 of 1
      • Proceed to remove the four 5mm Phillips screws that you just uncovered.
      Ask FixBot
    6. Panasonic DMC-FZ70 Back Frame Replacement: step 6, image 1 of 1
      • Slowly pull on both side of the camera, until both halves begin to separate from each other.
      • Do not pull too hard, as both halves are held together with ZIF connector cables.
      Ask FixBot
    7. Panasonic DMC-FZ70 Back Frame Replacement: step 7, image 1 of 3 Panasonic DMC-FZ70 Back Frame Replacement: step 7, image 2 of 3 Panasonic DMC-FZ70 Back Frame Replacement: step 7, image 3 of 3
      • Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
      • Carefully pull the ribbon cables out of the slot once they have been released.
      • Only the two indicated connectors need to be removed to separate the two halves of the camera.
      Ask FixBot
    1. Panasonic DMC-FZ70 Back Frame Replacement, LCD Screen: step 8, image 1 of 2 Panasonic DMC-FZ70 Back Frame Replacement, LCD Screen: step 8, image 2 of 2
      • Unscrew the five 5mm screws on the panel that you just removed.
      Ask FixBot
    2. Panasonic DMC-FZ70 Back Frame Replacement: step 9, image 1 of 2 Panasonic DMC-FZ70 Back Frame Replacement: step 9, image 2 of 2
      • Remove the entire silver panel to reveal the back of the LCD screen
      Ask FixBot
    3. Panasonic DMC-FZ70 Back Frame Replacement: step 10, image 1 of 1
      • Remove the LCD screen.
      Ask FixBot
    1. Panasonic DMC-FZ70 Back Frame Replacement, Back Frame: step 11, image 1 of 1
      • You can now access the back panel and the buttons on it.
      Ask FixBot
    2. Panasonic DMC-FZ70 Back Frame Replacement: step 12, image 1 of 1
      • To remove a button, lightly press its front face and it should detach with ease.
      • To put a button back into the camera, press on front its back face until it snaps back on.
      Ask FixBot
3 other people completed this guide.
Author
with
Emily Kuzmicky
469 Reputation
2 Guides authored
Cal Poly, Team 21-3, Maness Winter 2017 Member of Cal Poly, Team 21-3, Maness Winter 2017
CPSU-MANESS-W17S21G3
6 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 91
All Time: 1,858
