Panasonic Compact Shaver ES4815 Motor Replacement
    1. Panasonic Compact Shaver ES4815 Motor Replacement, Battery: step 1, image 1 of 3 Panasonic Compact Shaver ES4815 Motor Replacement, Battery: step 1, image 2 of 3 Panasonic Compact Shaver ES4815 Motor Replacement, Battery: step 1, image 3 of 3
      • Twist the release cap to expose the batteries.
      Ask FixBot
    2. Panasonic Compact Shaver ES4815 Motor Replacement: step 2, image 1 of 2 Panasonic Compact Shaver ES4815 Motor Replacement: step 2, image 2 of 2
      • Remove the batteries.
      Ask FixBot
    1. Panasonic Compact Shaver ES4815 Motor Replacement, Motor: step 3, image 1 of 3 Panasonic Compact Shaver ES4815 Motor Replacement, Motor: step 3, image 2 of 3 Panasonic Compact Shaver ES4815 Motor Replacement, Motor: step 3, image 3 of 3
      • Remove the razor guard by pushing its release buttons and pulling.
      Ask FixBot
    2. Panasonic Compact Shaver ES4815 Motor Replacement: step 4, image 1 of 3 Panasonic Compact Shaver ES4815 Motor Replacement: step 4, image 2 of 3 Panasonic Compact Shaver ES4815 Motor Replacement: step 4, image 3 of 3
      • Carefully pull out the inner blades.
      Ask FixBot
    3. Panasonic Compact Shaver ES4815 Motor Replacement: step 5, image 1 of 3 Panasonic Compact Shaver ES4815 Motor Replacement: step 5, image 2 of 3 Panasonic Compact Shaver ES4815 Motor Replacement: step 5, image 3 of 3
      • Remove the two 1.9mm Phillips #0 screws from the inner blades.
      Ask FixBot
    4. Panasonic Compact Shaver ES4815 Motor Replacement: step 6, image 1 of 2 Panasonic Compact Shaver ES4815 Motor Replacement: step 6, image 2 of 2
      • Remove the metal plate.
      Ask FixBot
    5. Panasonic Compact Shaver ES4815 Motor Replacement: step 7, image 1 of 3 Panasonic Compact Shaver ES4815 Motor Replacement: step 7, image 2 of 3 Panasonic Compact Shaver ES4815 Motor Replacement: step 7, image 3 of 3
      • Pull the outer casing with one hand while holding the inner battery casing with the other hand.
      Ask FixBot
    6. Panasonic Compact Shaver ES4815 Motor Replacement: step 8, image 1 of 2 Panasonic Compact Shaver ES4815 Motor Replacement: step 8, image 2 of 2
      • Detach the white plastic blade base from the tip of the motor by pulling it.
      Ask FixBot
    7. Panasonic Compact Shaver ES4815 Motor Replacement: step 9, image 1 of 2 Panasonic Compact Shaver ES4815 Motor Replacement: step 9, image 2 of 2
      • Detach motor from gray plastic holder by pulling it.
      Ask FixBot
muhammad samsulsham
253 Reputation
2 Guides authored
IUPUI, Team S1-G5, Harley Spring 2018 Member of IUPUI, Team S1-G5, Harley Spring 2018
IUPUI-HARLEY-S18S1G5
6 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 36
All Time: 952
